Home › Forums › Product Discussion & Questions › BeoGram › Beogram 2000 (same as 1203 or 3000) Type 5240: arm come back before lifting
- This topic has 6 replies, 3 voices, and was last updated 1 month, 2 weeks ago by
guigui37.
17 January 2026 at 17:56 #72650
guigui37
BRONZE MemberHi
it’s been a long time since my last post here 😀
Well, just got a Beogram 2000 which was very sick… with totally blocked motor (fixed easily, I became quite an expert in this exercice 😂)
Now it’s running really good but I have a problem I can’t solve: at the end of the disc, the arm starts to come back just a little bit before lifting up 😓😱… then it lifts and come back correctly : this is terrific for the stylus and the disc.
Does anybody now how to solve this ?
Maybe I have the answer in the coming sentence : the arm is moving a lot at its base, I believe it comes from there but I don’t know how to reduce this that movement, ..
17 January 2026 at 18:50 #72655guigui37
BRONZE MemberJust got the arm correctly adjusted (like my other Beogram)…but I still have no solution, no idea: arm returns back a little bit before lifting 😭
18 January 2026 at 10:41 #72681guigui37
BRONZE Member31 January 2026 at 19:48 #72997Peter8300
BRONZE MemberTry to take off the cam wheel and clean it thoroughly with water and soap and/or isopropylalcohol. All the levers should move freely including the cobber ones. There should be NO grease or oil on it.
That has helped me more than once.1 February 2026 at 17:25 #73024guigui37
BRONZE MemberI was going crazy… then I read your post.
Removed the cam wheel… dropped it in my ultrasonic cleaner with detergent and heat…
Dried it…
Got it back … and the dream came true 😃😃😃😃
So happy, the turntable runs like a brand new one !
So many thanks for you help.
The cam wheel was not looking greasy but yes it required to be deeply cleaned… basically.
Many many many thanks again 👍🏻👍🏻👍🏻
12 February 2026 at 13:18 #73596beovintage
SILVER MemberThe shaft of the lift mechanism might come up too slow, so grease it and make it move correctly
12 February 2026 at 14:56 #73607guigui37
BRONZE MemberThank you for your answer, on that side : it is working good.. correctly greasy. 😉
