Home › Forums › Product Discussion & Questions › BeoGram › Beogram 2000 & Beosound Ouverture DataLink
- This topic has 3 replies, 3 voices, and was last updated 5 months, 2 weeks ago by
Madskp.
20 May 2026 at 20:42 #123678
beoldn
BRONZE MemberI’d like to connect Beogram 2000 (1983 model) to Beosound Ouverture. Ouverture supports DataLink via AUX input but doesn’t have pre-amp.
It should be possible as shown in this video:
Any ideas how this can be achieved? Is there external pre-amp that supports DataLink passthrough?
Thank you.
20 May 2026 at 22:40 #123680 Mark-sfBRONZE MemberYes there is though not inexpensive at https://www.designedav.com/connect-bo-turntable-to-modern-systems. You can make one yourself with 7-Pin DIN male and female connectors where the L/R signal uses male RCA connectors to connect to an external phono preamp and pins 6 & 7 are directly connected with a wire between bypassing the preamp.
21 May 2026 at 07:33 #123694beoldn
BRONZE MemberThank you so much for the information. Very helpful.
21 May 2026 at 08:17 #123695Madskp
GOLD MemberAlso available here RIAA amplifier – OneRemote
There was also an older version in a cylindric form, that might be possible to find second hand
