Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › BEOGRAM 2000 (5821) : doesn’t stop automatillcay when end reached
- This topic has 0 replies, 1 voice, and was last updated 2 months, 4 weeks ago by
guigui37.
28 July 2026 at 08:38 #124719
guigui37
BRONZE MemberHi,I spent time to fix a Beogram 2000 (modern version)… and now my only problem is that when the end of the disk is reached, the arm doesnt go back.
If i take the arm a litle bit more to the center of the disc then the arm lifts and goes back.
I also notice than when the arm goes automatically back, it is not absolutely parallel to the border : in conclusion, my problem i that the arm is not correctly indexed on it’s axis.
On the old beogram (the ones from 60 or 70’s) it was easy to setup : you unscrew the screw on the bottom of the arm adusjt and then tighten the screw and that’s it.
On the modern model i absolutley have no idea on how i can adjust that.good to know : i had to fix two pins that are holding a part that is used for lowering and rasing the arm… maybe the is an impact on that ? (that part is working good now)
This topic was modified 2 months, 4 weeks ago by
guigui37.
