Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1700 – starts at wrong speed – 66 RPM
- This topic has 3 replies, 3 voices, and was last updated 11 months ago by
djhomeless.
25 May 2024 at 21:08 #55955
WoodyGA
BRONZE MemberHi from a newbie!
I recently acquired a Beogram 1700 that seems to be in great shape and I have an MMC 20 E pickup for it. I haven’t done anything to it except install the cartridge and a little cleaning. It does, however, have an odd behavior.
When I press the 33 key to start playing, it starts at 66 RPM instead of 33 (tested with one of those free phone apps). Pressing 45 starts at the correct speed. If I press 33, then 45, then 33 again before the tonearm lowers, it slows to the correct speed in time for the stylus to hit the record. If I press Pause, wait, then 33 again, it starts at 66 RPM. Pressing 45 then 33 slows it to the correct speed.
As I said, I haven’t done any work on it, though I have already bought and received a repair kit from beoparts-shop.com (Now: Danish Sound Parts).
This is a US T5733, and at some point in the distant past it was modified with RCA plugs instead of the expected DIN connector, but it looks like the original gray cable. It also has a separate black ground wire with a spade connector.
Other than the speed issue, it seems to be working well and sounds amazing, though I’ve only tested it with a preamp and a soundbar (I have a Beomaster 901 I’ll be restoring to go with this turntable).
I’m new to the Bang & Olufsen world, though I’ve been tinkering with and restoring old tube radios for a couple of years now. Any suggestions or pointers will be greatly appreciated!
—Woody
26 May 2024 at 15:23 #55970Dillen
ModeratorA worn and slipping belt can allow the motor to accellerate to easily.
The motor pulley simply slips on the belt at startup.This, coupled with electronics that will accept to lock in at twice the correct speed, causes this.
The cure is to replace the belt.Martin
26 May 2024 at 18:49 #55971WoodyGA
BRONZE MemberThat fixed it!
I had already ordered and received their belt in the repair kit, so I just popped it on and—bam! Fixed. Now I’ve learned a little more about these wonderful turntables.
Thank you so much for your help Dillen!
8 January 2025 at 19:32 #62415djhomeless
BRONZE MemberJust wanted to thank OP + Martin for this thread. Also have a 1700 with the same issue. Ordered a new belt from Martin which just arrived today, and my speed issue is no more!
Thanks all.
