Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1700
- This topic has 15 replies, 8 voices, and was last updated 3 years, 2 months ago by
NigelSethSmith.
9 November 2022 at 10:09 #40632
Baz1972
BRONZE MemberHi all,
I have the chance to buy a Beogram 1700 in very good condition but the seller says that when a record is played the arm is just basically gliding across the record to the spindle. I know these turntables have the anti skate set at the factory but is there anyway to adjust this myself. Any information will be gladly welcome
cheers
baz
9 November 2022 at 10:17 #40633Dillen
ModeratorWrong tracking force setting?
Bad stylus?Beogram 1700 is a wonderful deck.
Matin
9 November 2022 at 12:42 #40634Baz1972
BRONZE MemberNot sure on the stylus as I don’t have the turntable yet, can the anti skate be adjusted on a Beogram 1700? Cheers baz
9 November 2022 at 14:28 #40635Dillen
ModeratorYes, but it’s neither particularly easy nor apparent how, and not something owners typically mess with.
It’s far more likely to be one of the reasons I listed above.Martin
9 November 2022 at 17:44 #40636Baz1972
BRONZE MemberOk I will investigate both when I pick it up on Saturday. Cheers
9 November 2022 at 20:09 #40637 matadorModeratorBeogram 1700 is a wonderful deck.
Hi Martin, could you please elaborate on what “academically” makes a deck wonderful and why the 1700 is part of them?
Thanks.
9 November 2022 at 21:36 #40638Dillen
ModeratorWell.. they just always seem to be great performers.
Of the type 57xx family, Beogram 1700 was the newest of the “squares”.
It has the DC-servo controlled motor, it has the slimline tonearm with the round counterweight (read: easier adjustable tracking force) but still carries the good MMC20-series cartridge.
Good platter, and it doesn’t have the operation panel with the somewhat flimsy buttons found on the sloping models.All in all it’s just a stabile and solid build causing few problems.
Only thing you could argue is that it doesn’t have datalink.
15 November 2022 at 01:51 #40639Saint Beogrowler
BRONZE MemberI’ve alexia’s liked these. The brass
thing that raises and lowers the arm
gets gummed up with old lubricants on
these. A good cleaning and new lubricants
helps, and setting appropriate tracking force
will probably fix all
15 November 2022 at 01:51 #40640Saint Beogrowler
BRONZE MemberI’ve always liked these. The brass thing that raises and lowers the arm gets gummed up with old lubricants on these. A good cleaning and new lubricants helps, and setting appropriate tracking force will probably fix all
16 December 2022 at 19:25 #40641Dasbird
BRONZE MemberI picked up a Beogram 1700 from my parents that has been in their attic for 25 years. It was hardly ever used. I am trying to set it up for my daughter who loves her vinyl. I tried to play a record by pressing the 33 button. The arm will move over, drop, and then pick back up. It will continue to drop for a moment and then pick back up over and over until I hit pause and move the arm back. At one point it moved back and then moved 1/3 of the way across the record, dropped, and then continued to play without interruption.
I have not hooked it up to an old amp yet because I was trying to see if it even worked still or if the stylus needs replacement before I dig out my old amp and speakers. I am turntable rookie having grown up with Cassettes and then CDs. Can anyone provide any feedback on the cause of the issue? Is this an issue that can be fixed? The stylus is the original MMC20EN and it looks like the needle is intact, and when it does drop on the record you can hear the music. Any help is greatly appreciated!
20 December 2022 at 11:35 #40642JC
BRONZE Memberit has the slimline tonearm with the round counterweight (read: easier adjustable tracking force)
Did this newer and lighter tonearm sound different than the previous rectangular arm? It looks less solid to me.
20 December 2022 at 16:10 #40643Dillen
ModeratorIt’s solid enough, unless you misuse it or pack it badly for transport. But I suppose that goes for all tonearms.
Does it sound any different? – Well, not that I can tell, but perhaps it can be measured.
It’s much lighter and has a different resonance frequency.Martin
20 December 2022 at 19:40 #40644JC
BRONZE MemberThank you for responding.
The Beogram 1700 appears not to have a “stop” control-button, like the 1900/1902; a strange omission in my view. Now you have to touch the tonearm to return it after pushing “pauze”.
20 December 2022 at 23:08 #40645 Mark-sfBRONZE MemberThank you for responding. The Beogram 1700 appears not to have a “stop” control-button, like the 1900/1902; a strange omission in my view. Now you have to touch the tonearm to return it after pushing “pauze”.
You are correct. The only automatic arm movements supported are starting and end of record. Pause assumes you are going to manually move the tonearm so if you want to end a record early you do it manually through Pause.
21 December 2022 at 07:08 #40646JC
BRONZE MemberA nice solution could have been to touch the “pauze” button twice for “stop”, but perhaps that was too complicated to design in those days.
11 January 2023 at 11:31 #40647NigelSethSmith
BRONZE MemberSomething that caught me out with my beogram 1700. I set the tracking weight to 1.1 grams, I thought, and the stylus shot across the record. I’d actually set it to 0.11 grams. The calibration is in tenths of a gram. To get the 1.1 grams that the stylus needs, you set it to 11 (shades of Spinal Tap), i.e. one complete rotation of the counterweight plus one unit.
