Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1602 Tracking
- This topic has 4 replies, 3 voices, and was last updated 2 years, 3 months ago by
Mark-sf.
15 November 2023 at 06:54 #50484
tcraig
BRONZE MemberHi all,
I have searched these forums to the best of my ability and haven’t found any information on this subject, so I am posting a new topic. Apologies if I missed something obvious.
I recently inherited a B&O Beogram 1602 turntable. It has been in storage since 2002! and was lightly used prior to that so it seems to be in good shape. It has an MMC 10 E cartridge and the stylus is fine. The tracking weight is set to 1.44 g, which I think is about right, but I could be wrong. It starts up fine and rotates at speed, but as soon as the tone arm touches down, it skates inward. On turntables that I have owned in the past, this would be an anti-skating adjustment, but I can’t find any information about such an adjustment on the Beogram 1602. Is there such a thing? If so, how does one adjust it? If not, is there anything I can do to alleviate this problem? Any info would be appreciated.
Regards,
Tom
16 November 2023 at 02:26 #50485 Mark-sfBRONZE MemberMy guess is that you are not really tracking at that weight. How did you measure 1.44g?
16 November 2023 at 07:22 #50486Dillen
ModeratorYes, wrong tracking force setting. Check it with a gauge and reset the scale if it is off.
Or damaged stylus.Martin
16 November 2023 at 18:48 #50487tcraig
BRONZE MemberThanks for the replies. I measured the tracking force using a Proster scale that I bought. It came with a 5 gram calibration weight, which does register 5 grams on the scale. Short of obtaining multiple scales, I can’t think of a way to further validate the accuracy of the measurement.
The stylus looks okay from what I can tell and it does make sound when touched (very gently of course). Are there any other ways to check the integrity of the stylus?
I was thinking that I might increase the tracking force in small (say .25 gram) increments and see if a little more force would fix the problem. At what point do I risk damaging the stylus? (I’ll use some vinyl that I don’t care about).
Thanks again for the feedback.
Regards,
Tom
17 November 2023 at 17:24 #50488 Mark-sfBRONZE MemberWhat you are hearing when you physically touch the stylus is cantilever movement not the condition of the diamond. Have it checked under a microscope as it might be that the diamond portion might be missing.
