Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1203 motor bearings removal
  • #45636
    alf
    Member
    Hi All,
    Can someone guide me through the process of removing (replacing) the top motor bearing of my BG1203 that sits under the stepped pulley ?
    no trouble with the bottom bearing  but the top one puzzles me ?
    thank you so much ?
    ALF
    #45637
    alf
    Member
    I guess it would have been tricky to explain……the good news is: i worked it out myself.
    isn’t that nice ?! ???
    ALF
    #45638
    spassmaker
    Hi Alf
    Maybe you let all others know how you managed the deal with the stepped pulley.
    regards
    Christian
    #45639
    alf
    Member
    Hi Christian,
    refer to the service manual page 5-7 explosion drawing:
    remove motor from the turntable by unscrewing from its 3 anker points and disconnect.
    take off idler wheel (one thing less to worry about)
    take off the cover – item 184
    separate stator from the motor – item 177
    remove motor bracket, held in position by 3 rods and secured by one nut – item 164
    that frees up the rotor and its bottom bearing – item 178
    remove and replace bearing with its oil-soaked felt ring after cleaning.
    hope that gave some idea how to remove the bottom bearing
    ALF
