Home › Forums › BeoWorld around the world! › Français › Beogram 1203 : relay makes ugly noise and works bad
- This topic has 5 replies, 4 voices, and was last updated 2 years, 1 month ago by
Dillen.
27 April 2022 at 12:41 #34377
guigui37
BRONZE MemberHello,
I have a Beogram 1203… at starting (pressing the button) the relay makes an ugly noise… if i press a long time the button then the engine finally will start.
The orange part in the middle of this picture :
https://www.audiovintage.fr/leforum/viewtopic.php?t=4933&start=20
Do you think it’s a problem with the realy OR with the capacitor or other small electronic stuff that are soldered on the relay ?
Thanks for your help.
Je peux aussi écrire Francais 🙂 … c’est juste pour être plus éligible à plus de réponse mon anglais à la de Funès.
Bises à tous les fans BEO :o)
27 April 2022 at 16:33 #34378guigui37
BRONZE MemberDoes anyone know the value and the type of the capacitor inside the relay housing on a 1203 (or 3000 or 1202 or 1201 or 1200 or 2000 type 5240) ?
Quelqu’un connaitrait il la valeur et le type du condensateur se trouvant dans le boitier du relais d’une 1203 (ou 3000 ou 1202 ou 1201 ou 1200 ou 2000 type 5240) ?
Merci 🙂
27 April 2022 at 19:13 #34379 DeniscGOLD MemberHi, send a mail at the Beoworld member Dillen , i think , he can answer you.
28 April 2022 at 07:33 #34380guigui37
BRONZE MemberThanks you so much 🙂
2 March 2024 at 18:12 #34381jerome_nk
BRONZE MemberHi !
Did you get an answer ?
I’m facing the same issue on my 1203. 🙂
3 March 2024 at 08:39 #34382Dillen
ModeratorIf the relay is chattering, it could be the diode inside the housing has shorted.
I have seen this happen a couple of times.All fine inside the relay housing? – Check the adjustment and position of arms and levers
and that the small wire spring on one of the relay box arms is still present.Martin
