Home › Forums › Product Discussion & Questions › BeoGram › beogram 1202 teeth on spindle gear worn
- This topic has 2 replies, 3 voices, and was last updated 2 years, 4 months ago by
Dillen.
31 October 2023 at 01:27 #50015
beostuff
BRONZE MemberI just got a 1202 and the teeth on the spindle are very badly worn and it doesn’t engage with the arm mechanism. I am trying to remove the spindle but it seems to beheld in place by rivets! Any ideas on how to remove it? and where I might get a new gearing from???
1 November 2023 at 14:02 #50016 spassmakerBRONZE MemberHi
You are right, the spindle is held by a rivet and only to remove with some pulling on the rivet
I’ve a complete spindle / hub in my workshop, all teeth are ok, rivet is attached send me a pm.
Kind regards
Christian
1 November 2023 at 15:41 #50017Dillen
ModeratorThis?
Knock out the small steel pin that goes through the gear, then the hub with spindle etc. can be lifted up.
