Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1202/1203 – Noise from idler wheel
- This topic has 4 replies, 3 voices, and was last updated 11 months, 3 weeks ago by
Dillen.
7 February 2024 at 03:18 #52629
moonlight70
BRONZE MemberI have earlier tried to fix low speed and noise removal from my friends Beogram 1202. I did not manage to remove all noise, but some. The noise seems to come from the idler wheel when it is in action with the conical tip. I have tried new belt, new idler wheel, and installed new bearings in the motor. All bought from Beopart. But still there is some noise. Now I have bought two 1203. One of them has the same noise problem (video). The other one is completely silent, even though all the parts are really old. I wonder what causes the noise, and is there any tips and tricks to remove it?
//Lars
Title edited by Dillen as the serbian capitol has nothing to do with this topic.
7 February 2024 at 17:08 #52630Dillen
ModeratorMake sure the whole motor assy hangs free in its spring supports.
The motors metal bracket must not touch the nylon bushings (or metal carrier
bracket depending on version) anywhere (in normal playing position),
or you will experience exactly what you describe.Martin
9 February 2024 at 14:35 #52631moonlight70
BRONZE Member……The motors metal bracket must not touch the nylon bushings ……… Martin
Thanks Martin! I think the problem were there. The nylon bushings appeared to be fitted in the wrong order, so the opening space was too low. I compared with the quiet one.
17 January 2025 at 18:03 #62839Frederik Lund
BRONZE MemberHello. I have recently bought a similar model, the Beogram 3000, and i’m having the same issue, though i am not sure how to implement your solution. While it does look like my motor hangs free in the springs, how can i check or be sure? If i gently apply a force to it, i can move it in any direction (except up or down). Thanks in advance.
Frederik
21 January 2025 at 18:58 #62969Dillen
ModeratorPerhaps that missing up and down movement is the key.
