Home › Forums › Product Discussion & Questions › BeoCord › Beocord 9000 tape calibration never stops
- This topic has 5 replies, 4 voices, and was last updated 2 years, 1 month ago by
Sy Ben.
2 January 2024 at 10:57 #51804
citronix
BRONZE MemberEverything seems to be working except the auto tape calibration. It runs endless until I press stop. It shoud take 10-20 seconds, not 45 minuts,
I have read some old posts regarding the subject, but not found any answers
Anyone??
8 January 2024 at 03:14 #51805beolover.vn
BRONZE MemberHello, I also have a Beocord 9000 device encountering a similar issue with the Rec Cal not stopping. After a preliminary check, I used a multitester with a diode test function. When I applied it to pin 2 of 13P24, the Rec Cal function worked correctly. I’m not proficient in technical matters, and my capabilities only extend this far. I hope fellow enthusiasts can provide assistance.
YouTube link of my device: https ://youtu.be/Zur4gGsA4pY
15 January 2024 at 02:40 #51806 Sy BenBRONZE MemberYesterday, I had some free time and checked my equipment. I found that 13IC3 was short-circuited. I replaced it with a similar IC, and everything is back in operation. There is still another issue with EQ and sensitivity that I will continue to investigate when I have the time.
Favourite Product: Beomaster 8000
5 February 2024 at 19:18 #51807citronix
BRONZE MemberWell – I made it so far, that when I disconnetc the P26 – the 8 pin plug on PCB 11 – the DAC, the autocalibration turns of after been engaged for about 10 seconds – which seems correct.
But why – I still dont know
I have tried to replace PCB 11 and 13, one at a tim, with PCBs from a working machine – without any changes ;-(
7 February 2024 at 05:11 #51808artig
BRONZE MemberPresumably you know that you can get a readout of the values the calibration has found, so you can check if they have changed or if the results are reasonable? The procedure is outlined in the service manual. With Record Open press Stop and Tape Type at the same time. Display blinks 0000. Press digit 1 to 5 to display the values.
15 February 2024 at 07:57 #51809 Sy BenBRONZE MemberWell – I made it so far, that when I disconnetc the P26 – the 8 pin plug on PCB 11 – the DAC, the autocalibration turns of after been engaged for about 10 seconds – which seems correct. But why – I still dont know I have tried to replace PCB 11 and 13, one at a tim, with PCBs from a working machine – without any changes ;-(
I think the device is not functioning correctly logically. After performing REC CAL, the values will not be accurate
