Home › Forums › Product Discussion & Questions › BeoCord › Beocord 7000 tape stuck
- This topic has 4 replies, 2 voices, and was last updated 3 years, 7 months ago by
Minkyrich.
8 September 2022 at 08:48 #38905
Minkyrich
BRONZE MemberHi,i have a Beocord 7000, the tape deck hasn’t been used for a long time but i would like to sell my system so i tried a tape in it. The heads engaged but now out does nothing but make whirring sounds so i assume the belts have failed. How do i go about replacing them or getting them replaced. I was told to ask for @dillen as he’s the guy to go to?
9 September 2022 at 06:14 #38906Dillen
ModeratorA bit difficult, and it really depends on which version of drive is fitted in your Beocord.
But basically it’s a matter of rotating the flywheels by hand (Beocord unpowered) until
the tapehead bridge disengages.
Note that the two flywheels rotate in opposite directions; Left one clockwise, right one counter clockwise as seen from above.-And replace belts.
Correct belts here.Martin
9 September 2022 at 09:48 #38907Minkyrich
BRONZE MemberHi Martin, thanks for the reply. Is it fairly simple to do this, is there a good place to see photos or videos about it?
9 September 2022 at 13:02 #38908Dillen
ModeratorNone that I am aware of.
You must take out the drive and rotate the flywheels by hand – or using some kind of suitable tool to carefully push them round.Martin
11 September 2022 at 16:18 #38909Minkyrich
BRONZE MemberIs it difficult to take out the drive. I’ve seen a video of the 5500 and he made it look very difficult.
