Home › Forums › Product Discussion & Questions › BeoCord › Beocord 7000 doesn’t like the Beolink 1000
- This topic has 15 replies, 6 voices, and was last updated 2 years, 5 months ago by
Die_Bogener.
30 October 2023 at 10:06 #49999
mdg77
BRONZE MemberGood day everybody!
I gradually bought a Beosystem 7000. First the receiver. Then a record player. Now a cassette deck. The cassette deck didn’t work at first (the motor didn’t move, or it tried to move but stopped – probably a problem with the belt). A special workshop in Hamburg has now repaired the device. I connected it earlier. It works well. The problem is that it doesn’t respond to commands from the Beolink1000. I can only operate the device using the buttons on the “drawer”. Of course it could be that something is broken, but I actually think that there is some combination of buttons on the remote control and it suddenly works…
Does somebody have any idea?
30 October 2023 at 22:14 #50000 MillemisBRONZE Member1: The remote is faulty (did you check the batteries?)
Try another remote!2: The Beomaster is set to Option 0 – in which case it shall not respond to the commands of the remote.
3: The ir sensor/the ir circuit of the Beomaster is faulty.
Must be looked after by a service person (if you can not yourself).MM
30 October 2023 at 22:19 #50001mdg77
BRONZE MemberI just noticed that the cassette deck doesn’t even turn on when you switch the Beomaster to Tape.A. It only works if you turn it on by hand, switch the Beomaster to Tape.A and then operate the device using the buttons on the drawer. Is there a separate component on the cassette deck that “translates” the switching impulses from the receiver? Is this a vulnerable part?
30 October 2023 at 22:22 #50002mdg77
BRONZE Member0. Thank you for your answer!
1. I tried two different Beolink1000. Same Reslt
2. Beomaster works fine with the Beoagram, so I guess that isn’t the problem. Right?
3. Beolink works fine with the Beomaster itsel and with the Beorgam… so I guess that isn’t the prolem. Right?30 October 2023 at 22:24 #50003 GuyModeratorAlso check that the DIN plug connecting the Beocord to the Beomaster has 7 pins. If pin 6 or 7 are missing then there will be no communication between devices and no remote control of the Beocord.
30 October 2023 at 22:40 #50004mdg77
BRONZE MemberThe plug looks fine and fits perfectyl into the Beomaster…The pins are straight and complete.
30 October 2023 at 22:59 #50005 MillemisBRONZE MemberAlright then….it is just the cassette deck that does not work using the remote!
30 October 2023 at 23:04 #50006mdg77
BRONZE MemberAlright then….it is just the cassette deck that does not work using the remote? MM
Right. The Beomaster works with the remote. The Beogram works with the remote. I do not own the Beogram CD so I didn’t check that. The Beocord works, but only manually. I doesn’t switch on by remote, I doesn’t switch off when the Beomaster is switeched off and it can’t be controlled by the remote when I started a tape manually.
31 October 2023 at 01:40 #50007 trackbeoBRONZE MemberNext step eliminate potential failure of the Beosystem 7000’s DIN jack and data link driver for the Tape 1 socket by plugging the deck into Tape 2. (On the Beolink 1000, SHIFT then A.TAPE plays tape deck #2.) If that fails the same old way, you can either send it straight back to Hamburg or you can check the cable yourself by opening up the tape unit to check at the other end. If a break isn’t visible (or measurable with a meter preferably), then send it back to Hamburg for another (hopefully not expensive) fix.
31 October 2023 at 09:28 #50008 GuyModeratorThe plug looks fine and fits perfectyl into the Beomaster…The pins are straight and complete.
If trackbeo’s TAPE2 suggestion above does not work, I would open up the DIN plug and check that the soldered connection to pin 7 is still intact.
Pin diagram below – viewing from solder side of plug:
31 October 2023 at 09:55 #50009Die_Bogener
BRONZE MemberMost people pull the cable, not the plug.
Broken wires in the plug are very very common.
And since a 7-pin plug does not work with non-B&O and is replaced often with a 5-pin standard plug, there is no ir control. Usually the 2 extra pins get lost… and they are very rare and very expensive.
And when it comes back to B&O hardware, there is no 7-pin B&O plug available, since 7-pin are non standard and very expensive.
31 October 2023 at 21:32 #50010mdg77
BRONZE MemberFirst of all: Thank you very much for the great help here in the forum! And even if it’s very embarrassing for me: the error actually seems to be in the cassette connection from the Beomaster; The Beocord works with the Beolink perfectly on Tape 2. So far I have used a DIN plug with RCA outputs and inputs on Tape 1 in order to have a line-out signal; That’s why it never occurred to me that there could be something wrong with the connection. Thank you all!
1 November 2023 at 15:39 #50011Dillen
ModeratorNew datalink pins here:
Beoparts-shopMartin
2 November 2023 at 10:12 #50012Die_Bogener
BRONZE MemberNew datalink pins here: Beoparts-shop Martin
Yes, it’s very good that these very rare parts are available again or still available and that somebody takes a lot of care and love…
… but: these small parts are more expensive than 24 carat GOLD.
So it makes sense: take care on rare B&O parts!
They are more worth than pure gold.
Back to the problem: if Port Tape2 ist working, Tape1 is not working: Check the soldering of the Port connector. The solder on the Preamp makes problems and there are splits/cracks in the solder.
2 November 2023 at 15:48 #50013Dillen
ModeratorAnd some versions have protective diodes at the datalink signals. They can short.
2 November 2023 at 18:26 #50014Die_Bogener
BRONZE MemberYou are right, the Tape1 and the CD Port share the same protection diodes D1 and D2.
Tape2 and Phono use D3 and D4.
There is still no CD Player in the system for a test?
D1-D4 are on the Preamp Board.
