Home › Forums › Product Discussion & Questions › BeoCord › Beocord 6000 / 8000 | Fast Forward issues
- This topic has 7 replies, 5 voices, and was last updated 3 years, 6 months ago by
Glitch.
29 May 2022 at 05:49 #35123
notwist
BRONZE MemberHi all,
I have three Beocords languishing in storage and a fourth tape mechanism as a spare. All Beocord 6000 / 8000. And of the four mechanisms (all with new belts and lubricated) only one has a working fast forward. It is the mechanism not the machine, when I insert the working mechanism it functions in all three machines.
So this appears to be a very common failure in these mechanisms. But after reading the old forums I still don’t understand what is failing and what should be done about it. As far as I can see there is no difference between the 4 mechanisms. They all move freely and all parts move in the same manner.
Would someone be so kind as to point me to the problem origin? And what to dissasemble in the tape mechanism to restore the fast forward function?
Many thanks for helping me revive these beautiful decks.
BB
29 May 2022 at 08:05 #35124 chartzBRONZE MemberHi, and welcome to Beoworld ☺️
That’s indeed the usual failure on these machines. You have to renew every single idler tyre and quite possibly the broken clutch arm.
You will find the correct parts (buy the main belts too, beware of eBay random ones) at Beoparts.
Happy repairs! ?
29 May 2022 at 16:25 #35125notwist
That’s indeed the usual failure on these machines. You have to renew every single idler tyre and quite possibly the broken clutch arm. You will find the correct parts (buy the main belts too, beware of eBay random ones) at Beoparts. Happy repairs!
Is there any website or forum page where I can find more details? All belts have been changed with good quality ones (even purchased from Beolover). As far as I can see the Idler wheels are all in the same condition, I don’t expect it to be this. Dismantling the mechanism without knowing what you’re doing is a sure way of never getting it back together 🙁
BB
30 May 2022 at 12:16 #35126 spassmakerBRONZE MemberIf you got the right belts and renewed / cleaned all the Idler Rubbers even the small ones inside the mechanism as chartz mentioned there is a mistake which I made for myself, I took just only one cassette for testing which did’t work, took another and everything was fine.
Are the transport wheels which grab into the cassette running free? Common problem is sized lubrication on the spindles.
Have a closer look for the breakarms, one grabs inside the transport wheel, easy to mount wrong 😉 don’t ask me why I know this.
If all is done and still no progress you could change one wheel after the other from your working unit to determine which part is causing the failure.
Regards
Christian
5 June 2022 at 18:32 #35127notwist
BRONZE MemberHi all, Christian,
i’ve ordered the parts from Beoparts and they arrived. After an afternoon struggling with the re-assembly of the cassettte transport it is now working as it should. I compared the old and the new rubbers but aside from a bit of greyness they are identical in size and shape. I think that if you were to use ‘rubber renew’ you could easily get the same results. The tolerance appears to be very narrow, just a tiny bit too little friction will drop it off.
Now it’s off to my other three decks. Not really looking forward to doing it but after this one I think i’ve nailed the process ;-).
BB
6 June 2022 at 10:06 #35128 chartzBRONZE MemberWell done, and thanks for the update, always appreciated ☺️
17 September 2022 at 10:29 #35129imac22
BRONZE MemberHi,
I got the same problem with my Beocord 8000, shall not the brakes on the left side release then pressing ff?
Regards
17 September 2022 at 15:29 #35130Glitch
BRONZE Membernotwist: You asked about more detail… This video does a good job demonstrating some of the things mentioned above. https://www.youtube.com/watch?v=aBnIB4lDPzk
Glitch
