Home › Forums › Product Discussion & Questions › BeoCord › BEOCORD 5500 stops after 5 seconds
- This topic has 11 replies, 3 voices, and was last updated 2 years, 3 months ago by
KingdaKa1971.
5 December 2023 at 05:51 #51083
Jerryege
BRONZE MemberI have a BEOCORD 5500 and no matter what function i try it stops after 5 seconds. i have assumed it thinks there is no tape present so wondered if there was a sensor to detect a tape in place and running, but i cant see one and the only exploded view is of the BEOCORD 5000 which has a belt driven optical sensor. the 5500 does not appear to have this so maybe its another issue.
all lights up beautifully but after the 5 seconds it drops back into standby.
any thoughs?
5 December 2023 at 18:23 #51084Dillen
ModeratorTwo different tape drives were used in these autoreverse decks.
One type has a belt-driven tape motion sensor.Martin
5 December 2023 at 18:41 #51085Jerryege
BRONZE MemberThanks Martin. This doesn’t have a secondary belt. Any idea why it’s happening?
12 December 2023 at 17:22 #51086Jerryege
BRONZE Memberstill no further, the standby light is one and when I press any function it comes to life for about 5 seconds then goes back into standby. for the 5 seconds it appears to work correctly, just doesn’t carry on.
I’m a bit stumped. there is just one belt and I cannot see if there is a ‘tape running’ sensor as I had a similar issue with my old beocord 500 where it would stop if the tape counter belt wasn’t attached.
Any thought on what to look at next?
13 December 2023 at 07:57 #51087Dillen
ModeratorDoes both tape reels rotate during the few seconds when the tape is playing?
13 December 2023 at 08:12 #51088Jerryege
BRONZE Memberyes, functions appear to be normal. FF and RW also and it appears to track skip and i can ‘turn’ the head to reverse during play.
Even if i just press ‘display’ it lights up for a few seconds.
13 December 2023 at 08:43 #51089Jerryege
BRONZE Membercouple of videos. hopefully this helps
https://youtu.be/m2BaG_RZGIQ?si=9DQSfHSPFHiVLLxV
https://youtu.be/gdaNgqsImYM?si=3InhjeDOOX76SsC0
13 December 2023 at 17:35 #51090Dillen
ModeratorCould be the safety circuit kicking in. It kicks in if the motor is loaded abnormally.
This can happen, if something has seized or running rough in the mech. or if the belts are not correct (too thick or too tight).
– Ebay belts?Martin
13 December 2023 at 17:45 #51091Jerryege
BRONZE MemberBelt looks original and not tensions seams correct, not overly tight. I agree it looks that way but also cut off if you just press display or stop so no motor use at all. (See video)
I have another fully working 5500 so I may swap out the tape unit and see if I can isolate the problem to the mechanism or the circuitry
13 December 2023 at 19:11 #51092Dillen
ModeratorThe motor runs all the time, when the Beocord is out of standby.
13 December 2023 at 19:20 #51093Jerryege
BRONZE MemberOkay, I’ll try swapping out the mechanism so we can isolate the issue. It’ll give me the chance to check one against the other as well.
19 December 2023 at 18:48 #51094KingdaKa1971
BRONZE MemberI just had the same issue, after replacing the belt (yes, from Beoparts) on the Beocord 5500 it every time stopped playing/ff/rew, after 4-5 seconds. when checking, I discovered that the belt was pulling itself up to the side of the pulley of the motor (almost rolling off). The pulley was to deep to the motor. after pulling it back up so that the metal center and the pulley were aligned (and in line with the capstan wheels), the belt kept on the correct place. This did the trick in my case.
Probably I pushed the pulley in while handling the tape mechanism.
