Home › Forums › Product Discussion & Questions › BeoCord › Beocord 5000 type 4715 too slow
- This topic has 3 replies, 3 voices, and was last updated 2 years, 10 months ago by
chartz.
11 May 2023 at 03:09 #46556
Ickxsz
BRONZE MemberDear all,
After replacing all belts on my Beogram 5000/4715, the tape-speed during ‘play’ was noticeably too slow. I read somewhere that this can be adjusted by a certain potentiometer. Where can I find that?
I have the (French 80-page) Service Manual, so you can reply using the images in that SM.
Or should I first lubricate all bearings with a tiny drop of sewingmachine-oil?
Thanking you in advance for your reply,
Dirk
21 May 2023 at 10:23 #46557Ickxsz
BRONZE MemberEDIT:
Dear all,
After replacing all belts on my Beocord 5000/4715, the tape-speed during ‘play’ was noticeably too slow. I read somewhere that this can be adjusted by a certain potentiometer. Where can I find that?
Dirk
21 May 2023 at 16:30 #46558Die_Bogener
BRONZE MemberI would never turn anything around in B&O equipment… only when i exactly know what i’m doing.
Clean the drive, the axles, motor with alcohol… it’s 40 years old hard grease.
First clean it, then oil it. Remove the old stuff 100%…
Old grease and fresh oil: after 3 month you have a superglue. Nothing will move any more.
22 May 2023 at 08:26 #46559 chartzBRONZE MemberHi,
You possibly need to lubricate the capstan motor.
