Home Forums Product Discussion & Questions BeoCom Beocom 6000 rapid flashing
  • #64784
    CharlieWednesday
    GOLD Member
    Odd problem with one of my Beocom 6000 handsets, that I have never seen before.
    I put a new battery in this Mk1 handset a few weeks ago, but then I didn’t use it straight away and it has just been in a drawer.ย  I came to use it today, and after quite a short while (while I was trying to register it to a base), it just switched off.
    I figured the battery would be run down so I put it into a pyramid base and left it.ย  The LED did not flash, and it did not power up when it was put into the charger.
    After some time had passed, I came back into the room and the LED on the handset was flashing rapidly.ย  Not the usual flash like you would get for a missed call – it was flashing twice as fast, but the handset was still not powering on.ย  Then after a while, it made a low beep noise, the LED stopped flashing, and it just stayed off.
    I wondered if the battery might be faulty so I swapped it for another (I have a couple of new spares), but I still get nothing.
    I have just lifted it out of the charger and put it back in, the LED started flashing rapidly again, but no power.
    I lifted it again, put it back in, and it powered up and wanted to be registered to a base, but it didn’t last – after a few seconds, it switched off again.
    Any ideas?
    My B&O Icons: No description available No description available No description available No description available No description available No description available No description available
    #64786
    Guy
    Haver you tried a handset reset?ย  Press (dot) 7 000 9
    Also (but you may have done this), after a battery replacement you are supposed to press 9#9#9โœฑ655 OK
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #64789
    CharlieWednesday
    GOLD Member
    I had done a reset already yes, but I didn’t know about that new battery code – thanks.
    I had left it on charge overnight and when I checked it this morning it was powered on and wanting to search for a base.
    I entered the battery reset code you provided, and it said ‘battery flat’, then after a little while, it switched off.
    I’ll leave it on charge again while I am at work today and see what happens when I get back.ย  If I don’t have any luck I’ll try another battery – I have some new spares.ย  This one may be faulty.
    Thanks for the knowledge.ย  New useful info, from you, again!
