Home › Forums › Product Discussion & Questions › BeoCom › Beocom 2, what is missing ?
- This topic has 13 replies, 6 voices, and was last updated 2 years, 8 months ago by
trackbeo.
31 May 2022 at 03:23 #35212
jesuisrelou
BRONZE MemberHello everyone, first post ever.
I’m in the process of buying a Beocom 2 and I might have found one that suits my budget and has the color i’m looking for.
The seller sent me this pictures.
If i’m correct, it’s missing a way to connect it to a phone cable, right ?
Do I simply need to get a power supply with a phone cable like this one ?
Or do I need something more elaborated ?
Thank you very much for your help.
Charles
31 May 2022 at 04:14 #35213 GuyModeratorThat’s just the handset and charger so you’ll need to add a PSTN in order to connect to the phone line.
Have a read of this FAQ to work out which one to get: https://beoworld.org/faq_view.asp?id=74
PS: And welcome to the Forum!! ?
31 May 2022 at 16:19 #35214jesuisrelou
BRONZE MemberThank you for this quick answer.
So a power supply with a phone line would not work ?
31 May 2022 at 16:51 #35215 GuyModeratorSo a power supply with a phone line would not work ?
If you mean an original Beocom 2 PSTN charging base, then I cannot be sure. As stated in the FAQ, Beocom 2s were often updated with new SW to enable them to work with other B&O phones (eg BC6000) and share a PSTN. If the Beocom 2 that you are buying has had the SW update, then I am not sure if it will work with the original PSTN/charging base. Some of the Beocom 2s original PSTN charging bases simply had the phone line cut off once the phone itself had the SW upgraded.
31 May 2022 at 17:15 #35216 GuyModeratorA further thought: If your internet modem/router has built in DECT, then you may be able to connect the Beocom straight to it without purchasing a PSTN. I have used Beocom 6000s like this in the past – there will be reduced functionality but calls in/out should work fine.
31 May 2022 at 17:19 #35217jesuisrelou
BRONZE MemberThis is very interesting !
My box indeed have a built in DECT apparently.
I would have to buy the phone without being able to test it though. Buy it my be worth it in the end.
31 May 2022 at 19:13 #35218 Keith SaundersBRONZE MemberTo build on Guy’s comments, the following may help you..
BeoCom 2 Basic and BeoCom 2 System have the same hardware and look the same.
Only the software is different.BeoCom 2 Basic = software version 1.3
BeoCom 2 System = software version 2.2A software readout on the display is made by pressing following keys on the BeoCom 2 keyboard:
9#9#9 then INT then OKBeoCom 2 MK II is different from BeoCom 2 Basic and BeoCom 2 System as it has a smaller contact plate
on the plug for base/charger.
See the photo below.Location: Hampshire, England
3 June 2022 at 10:09 #35219jesuisrelou
BRONZE MemberHi there,
a quick update : i bought the phone without testing it.
It’s a 2013, MK2 device
I managed to link it with my router (freebox delta / France), so no base needed !
Thank you very very much for the help !
I was very surprised to be able to change the volume of my beomaster without any pairing procedure.
Only complain i might have is that the volume could be a bit higher.
Since i’ve never had one before, can’t tell if this is normal, but not a big deal anyway, the price i got was great.
3 June 2022 at 10:18 #35220 GuyModeratorGreat news – thanks for letting us know that the DECT connection worked. I don’t think many people are aware that connection can be so simple!
I can’t help with the volume issue, but perhaps there are other BeoCom owners who can advise.
29 June 2023 at 10:55 #35221dinyavin
BRONZE MemberDear Keith, may I ask you a stupid question: what is the difference (in functionality?) between BeoCom 2 Basic and BeoCom 2 System?
30 June 2023 at 07:49 #35222Valve1
GOLD MemberThis is very interesting.
How did you connect the Beocom with the DECT ?
30 June 2023 at 08:24 #35223 GuyModeratorThis is very interesting.
You may not get a response from jesuisrelou because the discussion about DECT is over a year old.
But from memory, when I connected my BC6000 to a DECT router/modem I simply used the handset’s ‘Register’ menu to search for the DECT base, and it found and connected with ease. Depending on the modem/router, you may need to log in to its setup menu to enable the DECT functionality and make it ‘discoverable’.
30 June 2023 at 09:44 #35224Valve1
GOLD MemberThanks Guy
Eddie
30 June 2023 at 17:01 #35225 trackbeoBRONZE Member(Note: that’s assuming you are not in the USA, which never received the DECT version.)
