Home › Forums › Product Discussion & Questions › BeoGram › Beocentre 9300 & Beogram 3000
- This topic has 1 reply, 2 voices, and was last updated 2 years, 1 month ago by
Guy.
16 November 2023 at 07:02 #50495
Simonjrwinter
BRONZE MemberWould these work together well as a pair? (Beogram 3000 type 59)
thank you
simon
16 November 2023 at 07:10 #50496 GuyModeratorThe BC9300 does not have built-in RIAA so in order to use the BG3000 you would have to add a phono/RIAA pre-amp.
I would look for a Beogram 3500/4500/6500 or 7000 with built in RIAA and datalink – thereby allowing you to control the turntable by remote. 3500/4500 are probably the best visual match with the BC9300.
This may help:https://beoworld.org/faq_view.asp?id=42
