Home › Forums › BeoWorld around the world! › North America › Beocenter 9500 No Output / Weak Right Channel
Tagged: Beocenter 9500, No Output, Secondary Speakers, Weak Channel
- This topic has 6 replies, 3 voices, and was last updated 1 year, 6 months ago by
Dustin Ortegon.
30 August 2024 at 15:44 #58722
Dustin Ortegon
BRONZE MemberGreetings All!
I just picked up a beautiful Beocenter 9500, my first B and O product. I brought it home to do initial testing of the unit, only to find that the Main Passive Speakers have NO output, the Secondary speakers have Left channel and a VERY faint Right channel. Headphone output is the same. Left Channel is good. VERY faint Right channel. (Basically sounds like an unamplified signal)
Before I tear into this thing, I want to reach out to the experts. I am thinking the muting relay is probably to blame for the dead main speakers, and possibly the STK IC for the Right channel issue. If you experts have any other ideas I would appreciate it.
Thanks! Oh, and the Powerlink sockets work with amplified speakers. No issue there.
30 August 2024 at 15:49 #58723 Guy
ModeratorHi and welcome to Beoworld! The BC9500 is a great first purchase.
First thing to check is simple: Are you sure that there isn’t a 3.5mm to 1/4 inch adaptor in the headphone socket? Sounds silly but this mistake has been made many times in the past!
EDIT: But if the headphone output has the same problem this is unlikely – apologies!
30 August 2024 at 16:04 #58725Dustin Ortegon
BRONZE MemberThanks! It really is beautiful. I saw it at the estate sale with a matching Beogram 9500 and had to have it. (Even though it was completely unneeded. LOL)
No adapter installed. I used a 1/4 inch plug to test my headphones. But I appreciate simple troubleshooting before tearing into a unit.
30 August 2024 at 17:13 #58728 lausviSILVER MemberThe muting relay is a likely suspect (trigger it on/off several times to see if there is any improvement).
Check if the “dummy plug” is installed in the LINE IN/OUT on the rear connections panel (if removed, the pre-amp signal won’t be going to the main amp, although this wouldn’t explain the partly working secondary speaker output…).
Also check the BALANCE adjustment.
30 August 2024 at 17:34 #58729Dustin Ortegon
BRONZE MemberI triggered the “Mute” a few times, I didn’t hear any clicks of a relay activating. As far as the Line In/Out plug, it is installed.
The Balance seems to operate correctly.
Thanks for the response.
10 September 2024 at 00:28 #58969Dustin Ortegon
BRONZE MemberUpdate: New relay at R1 installed and no change. Main L+R passive, no audio. Secondary R is good. L is weak.
Any ideas from experienced B and O techs?
24 September 2024 at 19:58 #59360Dustin Ortegon
Replaced TR22 and now the mains have audio. Main and Secondary Right Channel is GOOD. Main and Secondary Left channel is WEAK.
I am leaning towards an STK module. Do these regularly go bad?
Thanks!
