Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9500 display probleem
- This topic has 4 replies, 3 voices, and was last updated 2 years, 6 months ago by
Dillen.
30 July 2023 at 11:14 #47972
kronzilla
BRONZE MemberHello, i have a Beocenter 9500.
Everything workds perfectly, except, the display with the touch control is not lit.
A couple years ago i saw that the bottom display was dim and the top display worked perfectly. When i recently tested the system, the bottom display was completely dark, top display normally working. Everything else is just working.
Where do i need to start searching? I swapped a perfect working complete bottom display and still it does not working.
31 July 2023 at 10:07 #47973Die_Bogener
BRONZE MemberThe displays need 5V for the digital part and 7V for the leds… 7V missing?
31 July 2023 at 12:15 #47974kronzilla
BRONZE MemberI don’t know, need to check that.
But from the one to another day, the display brightness turned from 100% to 50%. I put the system in storage unused for about a year, after a year i powered it up, everything works except the bottom display, stayed dark.
19 September 2023 at 11:07 #47975kronzilla
BRONZE MemberAny idea where to search? Because everything works perfect, except that the lower display is not lit. I switched the complete lower 3 pcb’s for a spare (who i know works) but still no light on the displays. Touch- control is working as it should.
The lower display cable is entering the processor module. Maybe there is something wrong with the processor pcb?
19 September 2023 at 14:44 #47976Dillen
ModeratorDoes the lower display get any power?
If it gets power, does it get any data?Martin
