Home › Forums › General Discussion & Questions › General Discussion & Questions › Beocenter 9500 controller PCB assembly
- This topic has 7 replies, 3 voices, and was last updated 5 months ago by
Epic B and O.
26 November 2024 at 22:12 #61170
Epic B and O
BRONZE MemberHello All,
My Beocenter 9500 buttons have stopped working, and supposedly it’s a faulty controller PCB assembly.
Dose anyone know how to repair or where I could find a replacement?
I have attached photos.
any help would be greatly appreciated
just want to save my beautiful Hi-Fi I’ve owned since the 90s
Many thanks
michael
You must be logged in to view attached files.27 November 2024 at 07:02 #61173Dillen
ModeratorHave you checked if the lower glass panel has come lose?
If the glass comes away from its plastic holders, the conductive rubber bumpers will no longer
have contact.
It can also happen, if the glass was fastened using very thick tape.Martin
27 November 2024 at 22:39 #61200Epic B and O
BRONZE MemberHey mate
Thank you for your reply
Unfortunately it’s not the glass, because the buttons are still not working when you touch the rubber bumpers directly
Regards
Michael
28 November 2024 at 06:25 #61201Dillen
ModeratorHave you checked the backup battery?
28 November 2024 at 13:33 #61214Epic B and O
i haven’t.
when you keep your finger on the rubber bumper, they flash for a second
michael
6 September 2025 at 04:44 #69413Epic B and O
BRONZE MemberHello
Can anyone tell me what this part is called?
All I know it’s for a Beocenter 9500
Many Thanks
michael
You must be logged in to view attached files.6 September 2025 at 17:25 #69427 GuyModeratorIt’s referred to in the Service Manual (available to Silver/Gold Members) as the System Control PCB, also known as PCB40 – it contains the main microprocessor (under the metal cover). The attached battery is the backup battery (referred to earlier in the thread) that makes sure that the system retains its settings.
9 September 2025 at 00:51 #69489Epic B and O
BRONZE MemberMany thanks
much appreciated
