  • This topic has 1 reply, 2 voices, and was last updated 1 day ago by Guy.
  • #66299
    Joao Ferreira
    Hi all, i have a beocenter 9300 and the display on FM shows a different frequency from the one i am tunning, is there a way t adjust that?
    Thanks for any help
    #66316
    Guy
    Hi and welcome to Beoworld!
    You probably need to adjust the ‘FM offset’ – quite common if the set has been serviced and the tuner section disconnected or the microprocessor disconnected from the backup lithium battery.
    The process is explained on pages 5-1 and 5-2 of the Service Manual, which is available on Beoworld to Silver and gold members.ย  It is probably worth replacing the lithium battery before adjusting the FM offset, as explained here:ย ย https://forum.beoworld.org/forums/topic/beocenter-9300-puffer-battery/
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
