Home › Forums › General Discussion & Questions › General Discussion & Questions › Beocenter 9300 display
- This topic has 1 reply, 2 voices, and was last updated 9 months, 2 weeks ago by
Guy.
11 June 2025 at 15:16 #66299
Joao Ferreira
BRONZE MemberHi all, i have a beocenter 9300 and the display on FM shows a different frequency from the one i am tunning, is there a way t adjust that?
Thanks for any help
11 June 2025 at 21:05 #66316 GuyModeratorHi and welcome to Beoworld!
You probably need to adjust the ‘FM offset’ – quite common if the set has been serviced and the tuner section disconnected or the microprocessor disconnected from the backup lithium battery.
The process is explained on pages 5-1 and 5-2 of the Service Manual, which is available on Beoworld to Silver and gold members. It is probably worth replacing the lithium battery before adjusting the FM offset, as explained here: https://forum.beoworld.org/forums/topic/beocenter-9300-puffer-battery/
