Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9000
- This topic has 3 replies, 3 voices, and was last updated 1 day, 22 hours ago by
Martin Williams.
29 March 2022 at 08:40 #33610
Ipe
BRONZE MemberBeen working with Beocenter 9000. It does not work. When connected just hear relays sounds and some movement on CD / tape.
Changed already caps to power board but still the same.
Any ideas?
Location: Finland29 March 2022 at 23:51 #33611BRONZE MemberRelays clicking, the sound of motors whirring (that’s the doors), and a final relay clack are all good signs when power is applied. Next is basic CPU working at all, and ribbon cables connected, so: Does the little red dot in the upper right display show up? Do any of the buttons work? I.e. “Load Tape” & “Load CD” ought to whir the motors even if the doors are frozen shut. And “Sound” button ought to make the upper display show “Volume” and lower display show arrows lower left. Any of that? This much functionality is required before playing or amplifying anything. I don’t know enough to walk you all the way thru, but “does not work” is pretty broad. So maybe with these three answers or a few more details, others with more experience can make good guesses…
30 March 2022 at 06:08 #33612Ipe
BRONZE MemberHi,
No, there are no lights. No nothing. Just those clicks and clacks and that’s all. Went through all connections also. Actually I first thought that the problem were those caps but change did not make any difference.
Location: Finland31 May 2025 at 13:28 #65974Martin Williams
BRONZE MemberHi
did you solve the problem of having no power ?
I also have the same issue,just clicks and 1 second movement from motors
