Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9000 with active/passive speakers
- This topic has 1 reply, 2 voices, and was last updated 3 years, 9 months ago by
Guy.
13 June 2022 at 11:23 #35475
Hultan
BRONZE MemberRecent came across a beocenter 9000 and also have beolab 6000 and beovox rl60.2
is it possible to connect both speakers to beocenter and use together?
beovox to speaker output and beolab to line out pre amp.
14 June 2022 at 09:26 #35476 Guy
ModeratorThere’s no volume control on the pre-amp output, so you’ll need to find another solution. (EDIT: Actually there is volume control of pre-amp – I was thinking of line- out! Hence this should be useable for Beolabs))
Have a read of the second part of Steve’s response here: https://forum.beoworld.org/forums/topic/beomaster-3000-naar-powerlink/#post-5835
You could use the speaker 2 sockets (via attenuator) for the Beolabs. Be aware that the BeoCenter’s ‘Mute’ control would only work for the speaker 1 pair in such a setup, and does not mute the ‘pre-amp’ output.
I am sure that Steve will be along in a minute to confirm the correct cables!
