Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9000 CD decoder
- This topic has 13 replies, 3 voices, and was last updated 1 year, 8 months ago by
tonebells.
4 July 2024 at 22:41 #57196
tonebells
BRONZE MemberI am working on a Beocenter 9000 that has this CD decoder board.
The Philips axial caps are shot. I cannot seem to find the the parts info in the service manual for the B&O or the CD mec. One is a 1µf 63volt. It is marked 1µ0M. There is a 2.2µf 53volt marked 2µ2M. The other four I think are .47µf or 4.7µ 25volt. They are marked 47µM. All the 47s test around 8µf and over 20Ω. If anyone knows for sure what they are please let me know.
Here is a closeup.
Any input is welcome.
µ
4 July 2024 at 23:27 #57197 GuyModeratorWelcome to Beoworld!
I am guessing a bit here, but it looks very similar to the BC9500 decoder board. Have a look a the BC9500 service manual, which includes CD decoder circuit diagram and component list.
EDIT: BC9500 CD decoder was board discussed here – maybe swap notes! https://forum.beoworld.org/forums/topic/beocenter-9500-cd-decoder-board-repair/
5 July 2024 at 06:50 #57199Dillen
ModeratorThe one with the lifted pin in the last photo is a 47uF 25V.
How do you test them, and with what?Martin
5 July 2024 at 11:55 #57207tonebells
BRONZE MemberWelcome to Beoworld! I am guessing a bit here, but it looks very similar to the BC9500 decoder board. Have a look a the BC9500 service manual, which includes CD decoder circuit diagram and component list. EDIT: BC9500 CD decoder was board discussed here – maybe swap notes! https://forum.beoworld.org/forums/topic/beocenter-9500-cd-decoder-board-repair/
I will take a look this evening. Thanks for the info.
5 July 2024 at 11:57 #57208tonebells
BRONZE MemberThe one with the lifted pin in the last photo is a 47uF 25V. How do you test them, and with what? Martin
Peak ESR70. I will replace and see what happens. Thank You.
5 July 2024 at 12:50 #57210Dillen
ModeratorWhat are the symptoms?
5 July 2024 at 19:18 #57231tonebells
BRONZE MemberIt had the C2103 capacitor on the servo board issue. Once I had that fixed I started checking other boards. I know from past B&O repairs that these Philips caps have issues. These all tested bad and the main power supply caps were all leaking.
Tony
5 July 2024 at 19:49 #57233Dillen
ModeratorWhat did you fit as C2103 (brand/type)?
6 July 2024 at 02:08 #57235tonebells
BRONZE MemberI will need to look and see what I put in there. I had to move the unit off the work station while I wait for the power supply caps to come in. It will be a few days.
Tony
6 July 2024 at 09:32 #57239Dillen
ModeratorC2103 must be a blue axial Philips/BC. That’s the only type I have found to be guaranteed to work.
I suppose you would have known it, if you fitted this type, so I suggest you replace it again, this time with such one.Martin
6 July 2024 at 15:26 #57261tonebells
BRONZE MemberI installed a 33µf radial cap of some kind. If it works should it continue to work? Is it likely to become an issue? I have seen that the 138AML is recommended. 33UF is the closest I am coming up with.
Tony
7 July 2024 at 11:41 #57285Dillen
ModeratorIf the drive refuses to read the disc, the first thing to replace is C2103 (and the rest of the electrolytic capacitors on the servo board).
C2103 MUST be a blue axial Philips or BC. I know it sounds strange, but it is a fact that not just any capacitor from any brand will work in this position.
The capacitance is not that important, it could just as well be a 47uF, but fitting anything but a blue Philips/BC cannot be guaranteed to work.
It has certain filtering properties not found from other brands.
A convenient kit is available from Danish Sound Parts containing the right capacitor.Martin
13 July 2024 at 22:09 #5739617 July 2024 at 01:11 #57443tonebells
BRONZE MemberIt seems the CD is good to go. I replaced the power supply caps. Are there other preventative items that should be looked at?
Tony
