Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 8500 – Slow Tape FF & Rewind
- This topic has 2 replies, 2 voices, and was last updated 9 months, 1 week ago by
CharlieWednesday.
12 June 2025 at 12:10 #66320
machineageBRONZE MemberHi all!
I have a Beocenter 8500 which has been sitting for some time. I powered it up recently and it’s all working fine, except for the tape mechanism. The issue being fast-forward and rewind which are sluggish. It has the Mk1 mechanism with the single belt (which I’ve replaced). It plays fine in ‘forward’, but the take-up is again sluggish when playing in ‘reverse’. I understand the reel drives are powered by a separate motor with no belts. Could the sluggish behaviour be due to dried grease / requirement for lubrication, or something else? It does seem to have improved a little as I’ve been using it, but it’s still below par.
Thanks 🙂
12 June 2025 at 22:36 #66331 machineageBRONZE MemberOK – I fixed the issue 🙂
Upon disengaging the drive reel brakes, and disengaging the drive cog, I found both drive reels were stiff to turn manually. So for each drive reel: I removed the top circlip (which is microscopic, be very careful here!) then removed the drive reel components. I cleaned the drive reel shafts, and the drive reel bores with IPA. They all had evidence of dried lubricant / grease. I re-lubricated the shafts / bores and reassembled everything. The most difficult part is reinstating the circlips, which requires a very steady hand, and steadfast concentration. Upon reassembly, it was immediately evident that both reels were easy to turn manually. I powered the Beocenter up, and it’s now working fine! Play in both directions, FF & rewind are all operating as they should. I did notice the left drive reel was skipping a little when winding. This was more audibly obvious than visual. This was rectified by bending the drive cog metal stop away from the drive reel. I made three tiny adjustments followed by testing, until it was winding quietly with no skipping.
All sorted 🙂
13 June 2025 at 13:47 #66345 CharlieWednesdayGOLD MemberI have a Beocenter 8500 with the Mk1 tape deck, and mine has a similar issue (even after I replaced the belt). This sounds a bit complex and I’m not sure I want to risk the attempt, but thanks for the info anyway – I may give it a go.
