Home Forums Product Discussion & Questions BeoCenter Beocenter 8000 remote control
  • #72776
    David Samways
    Hi all, I recently acquired a Beocenter 8000 in nice working condition but without a remote. After purchasing a supposed aftermarket replacement for the Beolink 1000 (now heading straight back to the seller as it wasn’t) I’m wondering if anyone knows of an aftermarket remote that will work or if any other B&O remote, such as the Beo 4, will work.
    David
    #72790
    Guy
    Hi David and welcome to Beoworld!
    Can I first just check that this is the Beocenter you are referring to:  https://beoworld.org/beocenter-8000/
    If so, then either BeoLink 1000 (BL1000) or Beo4 should be fine to operate it.  I wouldn’t bother with the aftermarket versions, just find a decent working BL1000 or Beo4 on eBay for £30 to £50.
    Come back and ask if you have any further questions once you get hold of a suitable remote.
    David Samways
    Thanks for your reply Guy. Yes, that’s exactly what I have. Beo 4s seem to be more numerous and less expensive that the Beolink 1000, but I’ll keep an eye out for a decent example. It’s a shame the remote was missing, but at £100 for a working example including a pair of RL 1000 speakers I don’t think I did too badly.
    I have another question regarding running a line-level input sub-woofer which I’ll post seperately.
    Thanks again, David
