Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 7700 – Compatible with DAB+/Internetradio?
- This topic has 3 replies, 3 voices, and was last updated 1 year, 2 months ago by
Guy.
29 January 2025 at 19:56 #63206
Fabienne Andreoli
BRONZE MemberDear Community,
I inherited a Beocenter 7700 from my grandfather and would like to upgrade it to a DAB+/Internet radio using a Digitradio TechniSat 11 IR. However, I couldn’t find an AUX input and I’m unsure how to connect the Digitradio (I have already purchased a DIN adapter).
Is there a solution for this? Or is there no way to add an input to the Beocenter 7700?
Thank you very much for your help!
29 January 2025 at 20:47 #63208gordon mobbs
BRONZE MemberHi Fabienne
Use the tape 2 rca inputs (marked play) on the back and the TP2 setting.
Gordon
Favourite Product: Beocenter 7700
Signature: GLMobbs
31 January 2025 at 10:07 #63248Fabienne Andreoli
BRONZE MemberThank you Gordon. I can‘t find a input marked „play“ though. Is it one of the four on the right?
I tried to use the one with the grey blind plug as a DIN connection, but it probably is an output not an input?Attachments:
You must be logged in to view attached files.31 January 2025 at 10:28 #63250 GuyModeratorThe grey plug/socket is a loop through which enables you to add external tone control – it is of no use here and the grey plug should be inserted for the unit to play correctly.
The Tape 2 ‘line in’ phono/cinch/rca sockets are the next two along – left and then right. They should be labelled on the rear edge (behind the connection in your picture).
