Home › Forums › Product Discussion & Questions › BeoCenter › beocenter 7700 cassette runs at half speed
- This topic has 4 replies, 2 voices, and was last updated 3 years, 6 months ago by
Dillen.
4 October 2022 at 11:17 #39583
beostuff
BRONZE MemberHi. I have a beocenter 7700 that I’d changed all the cassette belts on – then let it sit for 9 months. Now the tape player plays at half speed. I’ve also noticed that the motor is always running – even if the radio is playing. Also (sorry there’s a few) the belt on the smaller wheel underneath the tape deck seems to be rubbing on the large aluminium wheel. That doesn’t seem right. Any ideas?
5 October 2022 at 07:38 #39584Dillen
ModeratorCheck the DC voltage to the motor with a scope. Look for correct voltage and amount of ripple.
6 October 2022 at 17:27 #39585beostuff
BRONZE MemberThanks will check it out. I have a feeling it’s something mechanical – as the position of the wheel with the smaller belt doesn’t seem right. I’ll check both. Appreciate it
9 October 2022 at 00:09 #39586beostuff
BRONZE Memberit seems to be that the pads that hold each spindle (that fit into the casette) aren’t being released so are providing pressure hence the slow speed. Trying to track down what releases those pads – any idea if both spindles get released upon play?
Thank
9 October 2022 at 08:16 #39587Dillen
ModeratorDid you lubricate using something that evaporates or dries?
