Home › Forums › BeoWorld around the world! › North America › Beocenter 2500 to Beovision 5
- This topic has 1 reply, 2 voices, and was last updated 40 minutes ago by
Guy.
19 August 2025 at 20:14 #68910
beoguy
BRONZE MemberI recently moved and my Beocenter 2500 no longer is putting sound through to my Beovision 5…I haven’t changed the wired (masterlink) connection. I’m sure this is an easy fix, and vaguely remember something about calling the tv the “master” and the Beocenter the “slave” but I don’t remember how.
I have a Beolink 1000 and Beolink 4 if that’s important to know.
Anyone remember how to do this??
Guy
Location: Niagara Falls, Ontario19 August 2025 at 22:07 #68912 Guy
ModeratorAssuming that the TV and BC2500 are in the same room, and the speakers are connected to the TV (which is the most usual set-up):
With the system at stand-by, using the BL1000:
Press SOUND then 0 then STORE (to put the BC2500 in A.OPT 0)
Press PICTURE then 2 then STORE (to put the TV in V.OPT 2)
Then try to operate as before.
(Double check all your cable connections also – if your audio centre is definitely a BC2500 then there should be an extra box (Beolink Converter) between that and the TV))
