Home Forums Product Discussion & Questions BeoCenter Beocenter 2500 service mode
Viewing 6 posts - 1 through 6 (of 6 total)
  • #61823
    orava
    I have BC2500 (2606) with no “clamper switch” connector on board 7, nor it has “program” key for “program 2630” sequense. Is there yet a another way to enter service mode?
    Problem with device is like on
    https://archivedforum2.beoworld.org/forums/t/9619.aspx
    L
    #61825
    Guy
    Are you sure?  It’s actually the microswitch that senses when the CD clamper is fully closed/open – see picture below:
    (You have to create short circuit from top contact to bottom contact – hold for 2-3 seconds and the display should read TEST MODE)
    orava
    Yes, I can foud switch but it does not go to board 7 as manual says, so I think is this some different version. Will try direct from switch.
    #61875
    Guy
    The manual (at page 7-5, and page 5-6) shows PCB7 in order to help you physically locate the switch with reference to the layout diagram on page 1-1.  There is no connection to PCB7.  The switch is actually connected to PCB5.
    EDIT:  And my photo actually showed a BC2300 which does not have the tape deck, hence PCB7 is not present.  But it’s the same switch as in the BC2500.
    orava
    Yes, I misunderstood manual, not ON board7 but behind it.
    Anyway I still cant enter service mode, shorting does nothing..
    CD mechanics is ok, working on other machine, so electrical problem prehaps.
    #71508
    ronaldus1
    H Orava,
    Did you finally got it working?
    I have more or less the same problem.  My machine is not booting at all. I don’t even get the standby led.
    What I discovered is that the keyboard is not scanning the keys (the collum1, 2 and 3 signals are not scanning).
     it is as if the processor is hanging in a loop.
    shorting the clamper switch also uses the keyboard scanning routine so maybe you have some kind of the same problem.  do you have the standby led?
    Regards,
    Ronaldus
