Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Beocenter 2300
4 August 2025 at 12:11 #68235
Jens Schou
BRONZE MemberCD does not spin. Laser replaced with no result. Any good ideas?
4 August 2025 at 13:25 #68240ModeratorDoes it start to spin and then stop – is there any rotation?
It could well be a problem with capacitors.
Have a look at the following threads, according to the type of CD module fitted:
(Older type, with curved laser path) https://forum.beoworld.org/forums/topic/beocenter-2300-cdm-4-cd-repair/
(Newer type, with straight laser path) https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50372
Location: Warwickshire, UKMy B&O Icons:4 August 2025 at 19:28 #68280ModeratorCD does not spin. Laser replaced with no result. Any good ideas?
Any politness? Like maybe “hello”, ‘hi there”, “thank you”… Things like that?
This forum is not GPT driven and you’re lucky a more friendly member than me did answer.
Anyway…
Location: Paris France1 September 2025 at 16:24 #69278Jens Schou
BRONZE MemberNo nothing happens exet for a sligt hum when I push cd button. Have also replaced all capacitors at the pcb.
1 September 2025 at 17:23 #69282ModeratorDo you have a remote, and if so does it work when you use a remote? Does the FM radio work?
