Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Beocenter 2300
- This topic has 9 replies, 3 voices, and was last updated 6 months, 2 weeks ago by
Jens Schou.
4 August 2025 at 12:11 #68235
Jens Schou
SILVER MemberCD does not spin. Laser replaced with no result. Any good ideas?
4 August 2025 at 13:25 #68240 GuyModeratorDoes it start to spin and then stop – is there any rotation?
It could well be a problem with capacitors.
Have a look at the following threads, according to the type of CD module fitted:
(Older type, with curved laser path) https://forum.beoworld.org/forums/topic/beocenter-2300-cdm-4-cd-repair/
(Newer type, with straight laser path) https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50372
4 August 2025 at 19:28 #68280 matadorModeratorCD does not spin. Laser replaced with no result. Any good ideas?
Any politness? Like maybe “hello”, ‘hi there”, “thank you”… Things like that?
This forum is not GPT driven and you’re lucky a more friendly member than me did answer.
Anyway…
1 September 2025 at 16:24 #69278Jens Schou
SILVER MemberNo nothing happens exet for a sligt hum when I push cd button. Have also replaced all capacitors at the pcb.
1 September 2025 at 17:23 #69282 GuyModeratorDo you have a remote, and if so does it work when you use a remote? Does the FM radio work?
9 September 2025 at 13:53 #69501Jens Schou
SILVER MemberYes the FM radio works, but the cd is not spinning. Have now replaced the whole cd unit with the pcb on it, and still not spinning.
9 September 2025 at 21:03 #69518 GuyModeratorWhat type of BC2300 do you have? Straight or curved path laser? And what CD module is fitted? Perhaps add some photos.
I would be checking power to the CD module, and the security of any ribbon connectors.
Is Pcb85 on beosond 3000 the same as in used in Beocenter 2300?
I have taken this question from your other thread (which I will delete). I looked that the BS3000 service manual and couldn’t find PCB85 – which PCB do you mean? With what function?
10 September 2025 at 09:10 #69527Jens Schou
SILVER Member10 September 2025 at 15:17 #69532 GuyModeratorThanks – the picture is useful.
Have you checked everything that is mentioned in the second of the two threads I posted earlier? This one: https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50361
Although it is titled ‘Ouverture CD not working’, in the linked thread I discuss fixing my technically similar BC2300, which is the straight laser path version like yours.
Have you got the Service Manual? (If so, at the very end is the CDM12 version, like yours – page 15-1 onwards. PCB89 is the ‘CD interface board’, shown on the right of your picture))
Have you entered the service mode and run the CD test modes? If so, what results?
Is the CD module (and the CD interface board on the right of you picture) getting power?
Have you checked all the ribbon cables and connectors?
Have you checked the polarity of the capacitors that were replaced? Have you reflowed the solder joints?
10 September 2025 at 16:01 #69534Jens Schou
SILVER MemberI Think IHawe a Power issue, so Will try to look for that First, but thanks for reply.
if any good ideas please let me know!
