Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 2 CD tray belt
- This topic has 2 replies, 1 voice, and was last updated 2 years ago by
Madskp.
11 February 2024 at 06:12 #52713
Madskp
GOLD MemberI have recently aquired a Beocenter 2 that need some attention.
For one thing belts. Beoparts shop has the belt for the Door mechanism, so no problems there.
But the Belt for the CD tray mechanism also seems to be a little loose (The tray can not fix the CD in place) , but Beoparts shop does not have a belt that will fit.
Does anyone have an alternative for this?
The Belt is round, 1.5mm thick, and aproximately 30mm outside diameter. The correct outside diameter may of course be a smaller number since the belt is loose.
Thanks in advance
14 February 2024 at 14:07 #52714Madskp
GOLD MemberHaving dismantled the whole CD tray to get a more precise measurement of the Belt I have now measured it to 29mm outside diameter.
I have found an Ebay seller who has belts in the right thickness with both 25mm and 26mm inside diameter.
Have ordered some and will see if the will work.
21 February 2024 at 16:25 #52715Madskp
GOLD MemberHave now received and installed the new belt for the CD tray. I used the 25×1.5mm one as the 26×1.5 was the same size as the existing one in the BC2.
The CD tray now works just as it should, and the BC2 can also play both CD’s and DVD’s
