Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 1 stand challenge 🙃
  • #123951
    Tomi Salamon
    Hello all 👋 I am a proud owner od MX4000 with Beolab 2500 and 4000 for the bigger tv. I have just acquired Beocenter 1 that came with silly standard stand. Not high enough to be behind the table and to tall to be on the table. Is there an option to buy longer pole without the base? I would need it to be at least 30 cm longer. I would also be interested in table stand for reasonable price. Thanks for suggestions where to look/what to do or your kind offers. Kind regards, Tomi
    Favourite Product: Beovision MX4000 + Beolab 2500
    Signature: Amiga + B&O LoVe ❤️
    #123993
    Tomi Salamon
    Update: I decided to keep otherwise nice stand and will put it on to epal6 60×80 pallete and maybe some kitchen counter wood 3,8cm or two to make it full surface.
    Only issue that remains is I got the TV without little allen bolt that fixates the stand and tv.
    Can someone post a picture and speca what kind of bolt should I get?
    Also should it go through the plastic frame or stick out.
    Thanks for the help in advance,
    Tomi
    #124013
    Tignum
    GOLD Member
    Hi Tomi, I like those BV1 stands!
    With a quick google: are these 4 screws? Two from above & two from below? Then they are M4 10mm long.
    Regards,
    Johan
