Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 1 Replace Contrast Screen
- This topic has 3 replies, 2 voices, and was last updated 3 years, 10 months ago by
Ventilate.
29 April 2022 at 06:30 #34461
Ventilate
BRONZE MemberIt says in the service manual you should rotate two screws at the bottom of the screen.
I try to rotate what appears to be screw covers with no success. It is very hard and slippery. Maybe they are really screw covers and should be removed?
I’m kinda lost.
Anyone here has done it?
29 April 2022 at 19:39 #34462 Mark-sfBRONZE MemberWhile I have not done it myself, the screws as seen in the parts figures are not threaded but keyed. Since they depend upon gravity to drop down, they could be simply stuck and once in the proper release orientation be pried downward with a spudger.
29 April 2022 at 22:09 #34463Ventilate
BRONZE MemberThank you for your answer.
I will assume that there are no screw covers and what Im trying to rotate are the screws themselves.
The thing is you have nothing to grab… Clean flush design but a pita to work with.
Will give it a try tomorrow
12 May 2022 at 11:56 #34464Ventilate
BRONZE MemberI’ve contacted B&O Portugal and talked to their repairmen who is in service for more than 30 years
To remove the contrast screen you need to remove the back cover and unscrew four long screws with springs.
The screen should come out easily.
No need to touch the screws that are in the manual.
