Beo5/ Beo 6 Remote Controller software
Home Forums Product Discussion & Questions BeoRemote Beo5 & Beo6 Beo5/ Beo 6 Remote Controller software
Viewing 7 posts - 1 through 7 (of 7 total)
  • #42649
    yanaaveegres
    Hello! Could you please tell me is it possible to find a configuration tool which will help me to program Beo5/ Beo 6 Remote using Windows PC?
    #42650
    BeoZip
    this is not the latest software but good for Beo 5
    https://www.mediafire.com/download/tjv9oy9agrk0sr2/CTSetup_5.12.exe
    good luck
    BeoZip
    and here is the latest SW for Beo 6
    https://www.mediafire.com/download/6s2l3qs88zqz9x1/CTSetup_6.84.exe
    good luck
    Стас
    Hello BeoZip
    I downloaded the program from your link, when I log in the program requires a login and password. Did I do something wrong?
    #69649
    Guy
    Hello BeoZip
    Just put a tick in the ‘work offline’ box and the software should work fine.
    Стас
    Thank you very much for your quick reply! I hope that I will be able to run the program!
    #69699
    matador
    Lot of documentation in BWII including a comprehensive guide from a fellow beoworlder.
    Also lot of threads, templates, tips and tricks and also free codes.
    Learning to program the remote is not an easy ride but it is very rewarding: Play with it and come back here with specific questions once you’re really stuck.
    Have fun!
