Home › Forums › Product Discussion & Questions › BeoRemote › Beo5 & Beo6 › Beo5/ Beo 6 Remote Controller software
- This topic has 6 replies, 5 voices, and was last updated 6 months, 1 week ago by
matador.
8 January 2023 at 11:46 #42649
yanaaveegres
BRONZE MemberHello! Could you please tell me is it possible to find a configuration tool which will help me to program Beo5/ Beo 6 Remote using Windows PC?
10 January 2023 at 21:58 #42650BeoZip
BRONZE Memberthis is not the latest software but good for Beo 5
https://www.mediafire.com/download/tjv9oy9agrk0sr2/CTSetup_5.12.exe
good luck
10 January 2023 at 22:01 #42651BeoZip
BRONZE Memberand here is the latest SW for Beo 6
https://www.mediafire.com/download/6s2l3qs88zqz9x1/CTSetup_6.84.exe
good luck
14 September 2025 at 09:41 #69646Стас
BRONZE MemberHello BeoZip
I downloaded the program from your link, when I log in the program requires a login and password. Did I do something wrong?
14 September 2025 at 12:01 #69649 GuyModeratorHello BeoZip
Just put a tick in the ‘work offline’ box and the software should work fine.
14 September 2025 at 18:45 #69665Стас
BRONZE MemberThank you very much for your quick reply! I hope that I will be able to run the program!
15 September 2025 at 20:23 #69699 matador
ModeratorLot of documentation in BWII including a comprehensive guide from a fellow beoworlder.
Also lot of threads, templates, tips and tricks and also free codes.Learning to program the remote is not an easy ride but it is very rewarding: Play with it and come back here with specific questions once you’re really stuck.
Have fun!
