Home › Forums › Product Discussion & Questions › BeoVision › Beo4, BV9 and Beocenter 2
- This topic has 6 replies, 4 voices, and was last updated 2 years, 2 months ago by
Guy.
24 January 2024 at 02:21 #52387
Ipe
BRONZE MemberHi
Need help with BV9, Beocenter 2 and Beo4.
Been trying to change all the possible OPT possibilities but
just can’t get it right:) Beocenter is connected with masterlink and scart to tv.
What might be the right option to this setup?
Step by step for dummies:))
24 January 2024 at 14:27 #52388 MillemisBRONZE MemberPage 10
24 January 2024 at 14:42 #52389Ipe
BRONZE MemberYep, have the same side open, but still don’t get it working:D
Now I picture and sound on tv, but still can’t use beo4 to controll DVD……….
Is it possible that there is some other solution? If I set options like in that pic
Beocenter does not accept any comands – no sound in cd and nothing from dvd.
Do I have to have ir in socket box ctrl?
25 January 2024 at 16:37 #52390 BeobuddyGOLD MemberMake sure you have a fully wired scart cable, Instructions are send through scart.
25 January 2024 at 17:38 #52391Ipe
BRONZE MemberThanks:)
Have check still that.
27 January 2024 at 09:22 #52392Ipe
BRONZE MemberThanks for the advice.
The reason for problems was that scart cable. I have a box full of those and the fifth was a proper one. They seemed to be fully connected but still there are some difference…..or just broken:)
And when you live long enough…………..:)
Syndicat des Constructeurs d’Appareils Radiorécepteurs et Téléviseurs
27 January 2024 at 11:00 #52393 GuyModerator^ Good old SCART leads!! I keep a large box of them just in case! (also for temporary connection of DVD1 and/or V8000 to amuse my grandson ?)
