Home › Forums › Product Discussion & Questions › BeoRemote › Beo 4 remote not working with Beosound Century
- This topic has 6 replies, 4 voices, and was last updated 4 months, 3 weeks ago by
Chris Barker.
30 October 2025 at 03:40 #70770
Chris Barker
BRONZE MemberHello all
OK – I’ve gone through the forums with this one, but seem to have got a bit stuck on pairing the above
was given a Century with a Beo 4 remote ( no serial number) -was supposed to be working with remote ä few years ago…
Century working ok ( except tape transport) – but remote not talking.
Remote has IR flash coming from it ( via camera phone verification)
So – thought IR module capacitors were bust – so ordered new from D SParts, and fitted today.
but still no joy
Century does flash 1 ( once) if I do the – Power sound 1 store – routine.
Have reset remote ( i think)
have removed batteries and powered down both units for half h and restarted – no joy.
what next?
Is the IR sensor in the Century supposed to flash at any point? – can’t see that happening via phone camera..but most prob just a receiver…?
Cheers
30 October 2025 at 07:03 #70771 CharlieWednesdayGOLD MemberIs it possible your Beosound Century is in Audio Option 0? On your Beo4 hold down Standby and press List, then scroll to Option?, then scroll to A.Opt, then press 1. This will ensure the Century is in ‘Receive IR Commands’ mode.
30 October 2025 at 20:57 #70792Chris Barker
BRONZE MemberCheers -yes – have done that – still no joy. – the display reverts to standard once you press 1 – should it flash?
30 October 2025 at 21:37 #70795 GuyModeratorIs the IR sensor in the Century supposed to flash at any point? – can’t see that happening via phone camera..but most prob just a receiver…?
No it doesn’t. It’s just a receiver.
The Beo4 display doesn’t ‘flash’ – it just reverts to normal. The Century’s power light should flash as you press 1, to signify that it has accepted the instruction.
Is your Beo4 standard or perhaps a hotel version? Is it one of these (all or which should work), and if so which? (click photo to enlarge – look closely at the button labels)
31 October 2025 at 04:49 #70806 carolpaBRONZE Memberis the Beo4 set to option 4 operation only?
31 October 2025 at 12:26 #70821 GuyModeratoris the Beo4 set to option 4 operation only?
I presume that’s the same as Permanent LINK mode? I was going to suggest checking that next! But this is cleared when batteries are removed (which Chris had tried).
1 November 2025 at 19:31 #70842Chris Barker
BRONZE MemberHello All – thanks for the reply – I’m not getting notifications, hence the delay in replying
Another q – if the capacitors on the IR unit were duff – would the Century on flash 1 when trying to be set up? – just trying to confirm I undertook some reasonable soldering!
re the picture – it’s the left one of the 5
Hope that helps?
Cheers
Chris
