Home › Forums › Product Discussion & Questions › BeoApp › Bang & Olufsen App – Beta version 5.x.x.
- This topic has 151 replies, 26 voices, and was last updated 2 years, 4 months ago by
Lalune.
20 September 2023 at 22:27 #49076
Millemis
BRONZE Member20 September 2023 at 22:31 #49077 Millemis
BRONZE MemberI know that non essential inputs were removed
What are ‘non essential inputs’?
20 September 2023 at 23:17 #49078Mbee
BRONZE MemberI wonder why this screen shows the arrow at the top by ‘tv’ and mine does notBecause you’re running this morning beta, and the triangle was added to this afternoon’s beta ?Go to TestFlight to get the latest version.20 September 2023 at 23:18 #49079Mbee
BRONZE MemberWhat are ‘non essential inputs’?
Seeing the remaining inputs, I’d say that approximately all inputs were non essential to the eyes of the UX designers ?
21 September 2023 at 09:15 #49080 Millemis
BRONZE MemberI wonder why this screen shows the arrow at the top by ‘tv’ and mine does notBecause you’re running this morning beta, and the triangle was added to this afternoon’s beta ?Go to TestFlight to get the latest version.Sorry, I am running the latest/the second beta – Version: 5.4.0 (5.4.0.23092044593)
Here is another screenshot.By the way, I can activate the ATV (which was the last activated source yesterday) using the play button and I can move the cursor there using left/right.
No option for up/down – no option for standby – no option (the still missing arrow/triangle) for activating any other source of the BST.This makes it pretty much useless.
21 September 2023 at 09:24 #49081 Millemis
In his post on the previous page Thomas/Mr Andersen calls them “sources with a non-deterministic outcome“……whatever he means by that ?
21 September 2023 at 09:37 #49082Floris2207
BRONZE MemberNon essential inputs is just my personal translation and kind of stuck in my brain while posting. however i got it from mr.Andersons 2nd bullet point:
“The source list was groomed too much, we just released a fix an hour ago for this. Some will not come back, for example Deezer. It only worked if Deezer had just been playing. In general, sources with a non-deterministic outcome will be removed.”
But as I said in my other post, I can’t imagine why the groomed it this exact way. I use the TV input a lot, since the soundbar itself is keen on saying “f it, you changed HDMI input on your TV so now I don’t know what to do” resulting in me having to change the speaker output to TV speaker, and than to the Beosound Theatre. (it is connected through HDMI E-ARC, on Samsung though)
Anyone else notice the warped play pause button? (reverted back to normal now?)
21 September 2023 at 12:35 #49083beojeff
BRONZE MemberI’m glad to see that B&O is listening to feedback. There really needs to be the full TV remote menu in the app for the Beosound Theatre. Sometimes the Theatre loses connection with the Beoremote One. In such instances we need some way to control navigation on the tv.
21 September 2023 at 14:31 #49084 HiortGOLD Member21 September 2023 at 16:26 #49085Floris2207
BRONZE MemberAnyone else notice the warped play pause button? (reverted back to normal now?)
Just tested the latest version and it looks okay
Yes mine was okey for some time, but it did happen again, I will try to recreate it in a way that it can be reproduced.
Got it right now again, so that’s at least the 3th time in 2 days.
24 September 2023 at 11:25 #49086 YannChrisGOLD MemberHello Beoworlders,
Well, this update is really un-user friendly.
Especially when your setup mixes ML and NL products as the source selector is reduced to the utmost minimum.
So I wish to roll back to the pevious version.
But how to do?
Have a nice sunday,
Yann.
24 September 2023 at 11:28 #49087 carolpaBRONZE MemberHello Beoworlders, Well, this update is really un-user friendly. Especially when your setup mixes ML and NL products as the source selector is reduced to the utmost minimum. So I wish to roll back to the pevious version. But how to do? Have a nice sunday, Yann.
open Testflight
open previous Builds
select 5.3.0
select Install24 September 2023 at 11:34 #49088 YannChrisGOLD MemberThanks Caropla 🙂
24 September 2023 at 11:55 #49089 Millemis
BRONZE MemberI did that too!
Up untill now the beta versions were fine to have running on my main iPad.
But not anymore.
This beta is absolutely unworkable in my setup (with a NL/ML Converter in the mix – for my 6500 CD player/6500 Master – and several ASE-based devices plus the BST).Could it be that the app team has only the new Mozart-based devices in mind and that the app is only tested on mobile phones?
Would be rather sad ?P.S.
Still have the beta running on another iPad here….just to see how it evolves.MM
24 September 2023 at 12:05 #49090 YannChrisGOLD MemberMM,
I can see that our setups are very close and I hope that legacy products will not be neglected in the future.
Yann.
29 September 2023 at 16:47 #49091 Millemis
BRONZE MemberSo, at least the source arrow show up on my iPad too.
However, this is how it looks (read: this is my only option on my M5……if there was anything connected there – not even the option to turn off the device/all can be found there).And this is the same with a pre 5.4.0 beta version
I can access what is in my setup from there ?
Please notice that there is more in that menu than what the screenshot shows —— I can swich to the Spotify app directly from there and I can turn off the device/all from there.Sorry, beta team – I can’t use the new beta ?
29 September 2023 at 17:20 #49092 Millemis
BRONZE MemberThis is how it looks for my Theatre.
Sure, I did not expect to see any linked sources there (I wonder if that will ever come with a Mozart product?)
I see lots of what I do not need there.
Why display the internal HDMI’, which I do not use?
Let me pick what I should see there – and the order.
Apart from the tv-tuner, I do not use the internal LG sources – why do the LG Channels or the Media Player etc show up there?Here is how it looked previously.
Admitted not well thought through either (I do not use YouSee Play), but still more like how I use the BST….including Spotify Connect, B&O Radio and Standby (which does not show in that screenshot).
P.S.
A similar comparison with new/old app for my V1 tv is even worse ?Is my use case so far off from what the betateam tests?
29 September 2023 at 20:26 #49093 YannChrisGOLD MemberMM,
I agree with you on the missing linked sources.
In the previous versions, these sources were also missing in the Theatre but were available in the Core’s sources list.
For the unused source, we need at least a way to reorganize the list in order to place them at the end.
Yann.
29 September 2023 at 21:43 #49094 Millemis
BRONZE MemberMissing linked sources in the BST is not an app issue, but a software choice for all Mozart-based……so it seems.
When B&O talk about keeping legacy products alive, they also should realize that – at least – some of us want to have these integrated with/connected with the new products.
But that is not for the app team to decide.
7 October 2023 at 18:27 #49095 YannChrisGOLD MemberHello Beoworlders,
A new version has been released a few days ago but did not dare to download it.
Did you notice any improvement?
Kind regards,
Yann.
