Home › Forums › Product Discussion & Questions › BeoGram › Are “test records” usefull with Beograms?
- This topic has 3 replies, 3 voices, and was last updated 3 years, 5 months ago by
Dillen.
26 October 2022 at 09:06 #40124
matadorModeratorHi alls,
Our beograms do not have (unless I’m mistaken) a lot of (if any) adjustments beside tracking force. No azimuth, no anti skating, no “whatever it is named I don’t even know what it is”…
Then I wonder if the common “Test records” meant to fine tune a deck are of any use for us?
27 October 2022 at 07:21 #40125Dillen
ModeratorOur beograms do not have (unless I’m mistaken) a lot of (if any) adjustments beside tracking force. No azimuth, no anti skating, no “whatever it is named I don’t even know what it is”…
Eh, what?
Which model Beogram are you talking about?
The term azimuth is mainly used with tapedecks, but the angle of the cartridge (rotation and/or parallelism) can be adjusted in many Beogram models.
So can anti-skating, even if a knob or dial for this is not in direct view.Test records are good for countless things.
Many of the following parameters and properties can be checked using
one or more test records, – and most can be adjusted or manipulated in some way;
Tonearm height, tonearm parallelism, tonearm rotation, (& tonearm length for tangential models), tracking angle, tracking force, anti-skating, platter speed, wow, flutter, rumble.
Also general stylus condition, channel separation, distortion, frequency response (stylus and RIAA) etc. can be checked using test records.Martin
27 October 2022 at 11:40 #40126Sia43
BRONZE MemberWhere can I find test-records?
27 October 2022 at 13:25 #40127Dillen
ModeratorYou can find test/calibration/alignment records in good shops, on Ebay or f.e. here:
https://www.discogs.com/search?q=stereo+test%20record&type=allNote, that test records should not be bought “used” unless you trust the seller.
If a test record was played using a bad needle, it could be damaged and absolutely worthless.Martin
