Home Forums Product Discussion & Questions BeoVision Apple TV Siri remotes and IR Beovision
Viewing 12 posts - 21 through 32 (of 32 total)
  • #49733
    Guy
      Bump just to check the thread is visible to all including non-moderators!  Hopefully the first post is back as it should be!
      #49734
      Madskp
      GOLD Member
        thanks a lot. It all looks like it should after my last edit
        #49735
        Madskp
        GOLD Member
          I am at my parents house at the moment, and looking into their Apple TV the remote seems to be the 3rd generation with USB-C and sw. 0X33.
          It does turn on their Beoplay V1, and do control the volume. However the volume function seems to be stuck somehow so it will keep turning up the volume even if I turn of the TV volume functions in the ATV settings. I will have to look into a way to reset the Siri remote to see if this behavior does continue.
          #49736
          Guy
            That’s strange – but if you can’t reset it and it’s less than a year old them you should be able to raise as a fault with Apple and get a replacement.
            #49737
            Madskp
            GOLD Member
              Madskp wrote: It does turn on their Beoplay V1, and do control the volume. However the volume function seems to be stuck somehow so it will keep turning up the volume even if I turn of the TV volume functions in the ATV settings. I will have to look into a way to reset the Siri remote to see if this behavior does continue.
              I’m at my parent again and have now tried to charge and restart the SIRI remote as described on Apples support pages. Now all functions seems to work, although I don’t have the same posiblities to do long time testing . I have nothing to add to GUY’s observations.
              #49738
              Guy
                It’s thread drift for this thread, but I am helping a relative sort out some tech/AV gear and have a Google Chromecast HD for a few days. I just tested it with my BV10-32 and realised that you can setup the Google Chromecast remote to control the TV’s volume in the same way that a siri remote does! The Chromecast menu also offers the facility to turn the TV off/on (I could only get ‘off’ to work) and to change inputs, but I couldn’t get the latter to work.
                I am quite impressed that such a cheap device (£35 in UK) has the IR codes to control a Beovision!
                #49739
                Madskp
                GOLD Member
                  It’s thread drift for this thread, but I am helping a relative sort out some tech/AV gear and have a Google Chromecast HD for a few days. I just tested it with my BV10-32 and realised that you can setup the Google Chromecast remote to control the TV’s volume in the same way that a siri remote does! The Chromecast menu also offers the facility to turn the TV off/on (I could only get ‘off’ to work) and to change inputs, but I couldn’t get the latter to work. I am quite impressed that such a cheap device (£35 in UK) has the IR codes to control a Beovision!
                  It is indeed quite interesting how both Apple and Google are integrating these B&O IR codes. Maybe they are just using common libraries of IR codes that are available.  However in case of B&O they also need the transmitter to be able to transmit 455Khz IR codes that other brands are not using, so I guess the hardware must also be made for it.
                  Sound like the Google Chromecast is not perfectly working though which was also the case with the 1st. Gen siri remote.
                  #61057
                  Guy
                    I just took a gamble on a 2nd gen, A2540 (lightning) siri remote, advertised on eBay as ‘not working/for parts’.  Total cost (incl P&P) £7.16.
                    It arrived today so I connected it to a charger, carried out a restart as described here and then connected it to my Apple TV 4K 3rd Gen.
                    It works perfectly, including IR control of B&O BV10-32 volume etc – seems to behave just like the later A2854 (USB-C) version.
                    I checked the SW version and it’s at 0x83 – which corresponds with the latest version issued in September 2023, according to this useful site: https://appledb.dev/device/ATVRemote1,3.html
                    I also noticed that the Apple TV now shows a Bluetooth Received Signal Strength Indicator (RSSI):
                    IMG_8925
                    So it would appear that the only version of the siri remote that does not allow IR control of B&O TVs is the 1st gen Rev A ‘white circle’ type.
                    #61058
                    Madskp
                    GOLD Member
                      Great info 😀 I will try to update the first post with your findings shortly.
                      I have yet to update my Apple TV 4/HD to a newer version so nice that you can provide the info 😀
                      #61060
                      Guy
                        One other observation:  With both the A2540 and A2854 remotes in the same room as the Apple TV, as soon as you connect one of the remotes to the Apple TV, the other immediate loses the ability to control the TV by IR.  It would seems that part of the remote ‘connection’ process is for the Apple TV to send a message to the previous remote, effectively clearing its settings.
                        #61063
                        Madskp
                        GOLD Member
                          I have just updated the first post with the new information
                          #61064
                          Guy
                            Many thanks 👍
