Home › Forums › Product Discussion & Questions › BeoApp › App version 6.0.2.xxx
- This topic has 24 replies, 10 voices, and was last updated 1 year, 7 months ago by
L1no.
19 August 2024 at 06:57 #58431
YannChrisGOLD MemberCorrect. And this is logical to you?
Yes and no
Switching between products is available on the main page, which is white.
Multiroom is available on the black bar related to the selected product.
So it seems logical from this point of view.
But I agree that the same colour scheme (clear or dark) for the whole app would be better.
Yann.
20 August 2024 at 14:59 #58487 Severed_hand_of_skywalkerBRONZE MemberFor me it’s not the colour that matters even though it goes against (UX standards considerations to make design distinctions by just using colour). It’s the fact that the interface is the same for both. Sometimes I want to connect to another speaker but all I end up doing is adding this new speaker to play multi room.
20 August 2024 at 17:00 #58488 YannChrisGOLD MemberI noticed another regression:
My BS Core is optically connected to BL50s.
To control volume, I have to:
- switch from Core to BLs on the product selection page,
- set volume,
- go back to the product selection page to return to the Core.
Which is rather long and uneasy
On 6.0 version:
- I also had to switch from Core to BLs on the product page
- BUT the “now playing” screen remained at the bottom of the active product page
- so I could easily pass from the Core to the speakers to control volume level.
Yann.
21 August 2024 at 15:05 #58503XavierItzmann
BRONZE MemberVersion 6.1 on iOS/iPad iOS is the best version of the B&O app I’ve ever had.
Multiroom volume control still wonky in that sometimes I can JOIN in other rooms, and the joined room will start to play at its default volume, and get a check mark (because it is joined), but its volume bar will not display the currently set volume, unless one increases it or decreases it, using the volume bar slider. Following such an adjustment, volume is displayed.
2 September 2024 at 11:41 #58798L1no
BRONZE MemberI’m also experiencing the volume problem, sometimes it also ignores the default volume and starts the at volume zero when join is performed trough the app .
new for me is that the Beosound Core shows a option to set connected speakers but does not appear to do anything.
Other : Album arts only shows with radio, new layout removed the speaker setting option for my V1.
