Home › Forums › General Discussion & Questions › General Discussion & Questions › Added additional NL/ML converter to system – Part 1
- This topic has 1 reply, 2 voices, and was last updated 33 minutes ago by
carolpa.
20 September 2026 at 17:49 #125605
patcherley
GOLD MemberWhen I first got my Beovision Eclipse I was told by B&O that the only way to play BM7000 sources on the Eclipse was to physically connect the Eclipse and the BM7000 which I did for a while. Then @millemissen pointed Eclipse is an NL product and it should just work.
It did but not the way expected, if I select Radio via the Beo4 the Eclipse just plays the Radio. I do not see the 2 overlapping squares and Radio on the Beoremote. I have since added a Beosound Core to the system and that works as expected.
Well that was the case until I added another NL/ML converter, thanks to Multicare who repaired it for me. Now pressing Radio on the Beo4 switches the radio on but it doesn’t play through the Eclipse. I have to Join the Eclipse and it works fine. The second converter is connected to a Beosound Overture.
I have some more queries about the setup of the second converter which I shall post separately.
Any ideas what has happened. I did earlier in the week have problems with the Sound centre disconnecting from the LG TV twice and needing to power down and back to restore the connection
Regards Paul
Favourite Product: Beolink 7000
21 September 2026 at 16:31 #125621 carolpa
BRONZE MemberWhen I first got my Beovision Eclipse I was told by B&O that the only way to play BM7000 sources on the Eclipse was to physically connect the Eclipse and the BM7000 which I did for a while. Then @millemissen pointed Eclipse is an NL product and it should just work.
Do you use a Beo4 with the Eclipse? Does it realy work or do you have actually a Beoremote One?
The JOIN command is equeal to the overlapping squares.Well that was the case until I added another NL/ML converter, thanks to Multicare who repaired it for me. Now pressing Radio on the Beo4 switches the radio on but it doesn’t play through the Eclipse. I have to Join the Eclipse and it works fine. The second converter is connected to a Beosound Overture.
Regards Paul
So your setup is
- Eclipse (with Beolabs/speakers connected)
- Beosound Core (with speakers connected) is one or both BLC set as primary en secundairy products set? Or not at all?
- Beolink NL/ML converter (BLC) and ML connected to a T1611 converter PL/DL connected to a Beomaster 7000; speakers connected to the BM7000 or Core?)
- BLC with Ouverture ML connected; speakers connected to the BLC or Ouverture?
Please answer the questions to get a appropiate advice in your second post.
Note: the BM7000 and Ouverture Radio in principle will not be working anymore in the NL.
