Home › Forums › Product Discussion & Questions › BeoLab › A question for Geoff Martin on BL8000 Damping…
- This topic has 29 replies, 12 voices, and was last updated 2 years, 4 months ago by
Dillen.
24 June 2022 at 01:42 #34354
mojofml
BRONZE MemberThank you for this!
I have a stupid question (I’m new to this) – how important is it to use the original damping foam parts from b&o? Will it make a significant difference to the sound quality? To me it just looks like foam that I can potentially source elsewhere, or at least something very similar. Is there any easy alternative someone can suggest that I can use? Someone mentioned in another forum they used a magic eraser.I called my local B&O dealer (in Hong Kong), they explicitly said they do not sell parts individually. Also, what’s shown in the picture doesn’t look like what was in my original beolab 6000, hence the questionHere’s what my original foam looks like: [url=https://postimg.cc/Fd9PMMvW][img]https://i.postimg.cc/Fd9PMMvW/IMG-20220623-210634.jpg[/img][/url]Thank you!Your dealer should be to order the foam for your BL 6000 as a spare part from B&O. In this auction can you see the number ….. https://www.ebay.de/itm/154203121920?hash=item23e738e900:g:O1IAAOSwSXFdpIDw good luck
24 June 2022 at 07:19 #34355BeoZip
BRONZE MemberYour original black foam is exactly the same poison foam as in the old BL8000 and damage your BL6000.
The new white foam in my pic makes your BL6000 happy again.
I dont know if an other foam better or the same working in your BL but I think the original is the best. When your dealer would your BL repair so he takes the original from B&O.
You can try an other dealer to send you the spare foam. Maybe he is more flexible with you.
good luck
24 June 2022 at 07:26 #34356 YannChrisGOLD MemberNot relevant reply, sorry.
12 July 2022 at 19:23 #34357 YannChrisGOLD MemberHi Beoworlders,
That’s it, my BL 8000 are now finished:
After an extensive cleaning following Matador’s tutorial:
-New damping material placed,
-Foam tape exchanged with Beobuddy’s supply,
-Bushings of the main transformers exchanged by new ones supplied by Beoparts (part number RP-008 proposed for BL Penta, 3000, 4500, 5000).
They shine like new!!!
My warmest thanks to all contributors of this brilliant thread,
Yann.
18 February 2023 at 06:43 #34358HarryIV
BRONZE MemberI just got a set of foam from the nearest b&o dealer. It was no problem to just order the part. They charge €15 a piece. So you should not try to fabricate it your self for that price.
18 February 2023 at 06:49 #34359mojofml
Wow that’s great! Wish the Hong Kong b&o dealer would offer the same, and price is very reasonable
18 June 2023 at 12:03 #34360jaspers1996
BRONZE MemberWhere’s that? Can’t for the life of me find a supplier in Belgium. Only option seems the be the one seller on eBay who charges 60 euros a piece now
19 June 2023 at 14:16 #34361 BeobuddyGOLD MemberFoam for the BL8000’s aren’t manufactured or on stock anymore. So, find yourself a set at a dealer who’s willing to sell you (tricky question when they know they can’t order anymore)
19 June 2023 at 15:37 #34362 carolpaBRONZE MemberWhere’s that? Can’t for the life of me find a supplier in Belgium. Only option seems the be the one seller on eBay who charges 60 euros a piece now
ask him for his best price.
8 December 2023 at 16:49 #34363Dillen
ModeratorWhere’s that? Can’t for the life of me find a supplier in Belgium. Only option seems the be the one seller on eBay who charges 60 euros a piece now
Not in Belgium, though.
