Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Report Problems with the Site Here › Reply To: Report Problems with the Site Here
16 November 2025 at 14:54
#71235
GOLD Member
Hi Mark,
When I try to upload a picture using the “insert image” key of the menu bar, the message “upload failed for xxx”.
I used small size jpg files in order to minimize the load on the server and they are uploaded without problem as an attachment.
But it is far less practical since you cannot insert images to illustrate your “words.
Where is my mistake?
It might be useful to add “how to” guide as a sticky note.
Kind regards,
Yann.
