Home Forums Product Discussion & Questions BeoSound Beosound 5 / Beomaster 5 Setup Questions Reply To: Beosound 5 / Beomaster 5 Setup Questions
#70559
Guy
Member
4) The LCD on the Remote, BEO4 does not work properly(may need replacement, no idea from where) so will need a new LCD as I cannot see the display clearly.
First try adjusting the contrast – see the Beo4 manual for instructions how to do so*.
If it does need a new screen (as the photo appears to show), they are available here:  https://avaservices.co.uk/
And screen replacement instructions are here:  https://archivedforum2.beoworld.org/forums/p/21827/180454.aspx
* If not in the instructions, do this:  On Beo4, press Power (red dot) and LIST together.  Then press MENU and GO together.  Press LIST until screen shows: CONT:XX.  XX is a number from 00 to 15.  Type in new number to change (start low – 00 is lowest contrast), then GO to save, and Power (red dot) to exit.
